Junior Hacksaw Blades
Home Forums General Questions Junior Hacksaw Blades
  • #26184
    Harry Wilkes
      @harrywilkes58467
      Harry Wilkes
        @harrywilkes58467
        The last lot of junior blades I purchased from B&Q have not lasted very long, they cut well at first but sooner went dull. I was thinking of getting some Eclipes but before doing so I thought I'd asking what the forum members are using ?
        Thanks
        H
        #371697
        John Rudd
          @johnrudd16576
          Eclipse…..
          Buy cheap buy twice…
          #371701
          Brian H
            @brianh50089
            I'm using Eclipse; once bitten etc.
            #371703
            Gary Wooding
              @garywooding25363
              Eclipse for me, too.
              #371705
              Brian G
                @briang
                Eclipse, I'm still working through my father's 1970s stock I have bought some Groz blades to try, but it is too early to say how they compare (although they are much better than the blades that come with cheap junior hacksaws).
                #371711
                Brian Oldford
                  @brianoldford70365
                  Do B&Q actually use metal in their junior hacksaw blades?
                  #371713
                  Ron Laden
                    @ronladen17547
                    Sandvik is what I,ve been using and they seem to cut well and stay sharp.
                    #371717
                    Dalboy
                      @dalboy
                      I have only ever used eclipse had no problems with them
                      #371720
                      Thor 🇳🇴
                        @thor
                        Like Ron, I use Sandvik because that is what is available where I live.
                        Thor
                        #371723
                        mechman48
                          @mechman48
                          I am using up old stock of eclipse that I found whilst clearing up my old toolbox, have used blades from B & Q… rubbish. you can generally tell a good blade… eclipse blades have a spring feel to them when you bend them ,& snap cleanly & crisply whereas other cheapo diy blades will easily bend & break without a clean snap, you can actually feel the diy blade failing ( crackling sound / sensation ), so when ever I find eclipse blades I buy half a dozen or so to keep stocks up.
                          George.
                          #371726
                          Speedy Builder5
                            @speedybuilder5
                            By mistake, I bought Junior hacksaw blades which were marked "For Wood". OK for cutting up Chedar Cheese, but not much else !
                            BobH
                            #371730
                            Harry Wilkes
                              @harrywilkes58467
                              Posted by Brian Oldford on 14/09/2018 15:29:19:
                              They taste like metal ! Thanks guy's I will get some Eclipse yes
                              Thanks
                              H
                              #371748
                              the artfull-codger
                                @theartfull-codger
                                Eclipse make good hacksaw & jnr hacksaw blades which I use but I don't rate their piercing saw blades though,much prefer vallorbe swiss blades [more pricey !!] but much more accurate & easier to use.
                                #371759
                                pete hammond
                                  @petehammond94283
                                  The beauty of an old/well lived workshop is- you tidy up behind a bench or cupboard and find new unused but old in years, meaning sharp and good ,hack saw blades other similar goodies and lots of swarf that's out to get you!
                                  #371762
                                  larry phelan 1
                                    @larryphelan1
                                    B&Q and others do use metal in their blades,but it,s mixed with putty,and not even good putty !
                                    No doubt they have their uses,I just have not found what they might be.
                                    #371779
                                    Dod Mole
                                      @georgeclarihew
                                      Ah, but which direction do the above users fit the blade, cut on the push stroke or cut on the pull stroke.
                                      I find that blades last much longer cutting on the pull stroke, at least they do in the pupils hands at work.
                                      #371786
                                      Hopper
                                        @hopper
                                        Posted by George Clarihew on 14/09/2018 22:57:08:
                                        Standard procedure in some European countries. I always wondered why the Swiss and Italian guys I worked with did that. All they could tell me was "because it is the correct way". Maybe you have discovered the secret. Makes sense when you think about it.
                                        #371789
                                        not done it yet
                                          @notdoneityet
                                          The direction of cut may well depend on the frame. Every push cut, with a flimsy sprung frame, may well reduce the blade tension. Not good.
                                          #371799
                                          Brian G
                                            @briang
                                            I wonder if our practice comes originally from woodwork, a coping saw is (edit: usually) pushed so that any splinters are on the back of the work, and a fretsaw is pulled so that any splinters are underneath. Similarly we push a junior hacksaw and pull a piercing saw.
                                            Edited By Brian G on 15/09/2018 08:05:22
                                            #371800
                                            john carruthers
                                              @johncarruthers46255
                                              I thought I was buying Eclipse but as the tooth profile was 'rounded' and they could be tied in a knot I doubt they were the genuine article. Beware.
                                              Luckily a neighbour is issued blades at work and he gave me a box full.
                                              No name but excellent blades.
                                              #371809
                                              Brian Wood
                                                @brianwood45127
                                                Japanese wood saws cut in the pull stroke and are therefore very slim and flexible They also leave a nice clean cut
                                                #371832
                                                Ian S C
                                                  @iansc
                                                  I use Eclipse blades, my regular frame is one of the screw tensioned type and I push on that, I have a deep frame spring one, and pull on that(its about Xs 3 the depth of a standard frame. Once when exploring one of the hard ware retailers in Christchurch I'm sure I spotted Bi-metal junior blades (15/20 yrs ago). Then there is this.
                                                  Ian S C
                                                  Ross Yoke motor
                                                  #371836
                                                  Bill Phinn
                                                    @billphinn90025
                                                    Posted by Hopper on 15/09/2018 02:45:12:
                                                    In the case of jewellers' saws there's a very straightforward utilitarian reason why the blades are orientated with the teeth pointing towards the handle: the default position for the saw in use is vertical, with the handle at the bottom. Among other things, this allows gravity to assist the cut. The workpiece is usually held flat on the wooden benchpeg and shifted about as cutting proceeds.
                                                    #371940
                                                    michael howarth 1
                                                      @michaelhowarth1
                                                      I always used Eclipse blades because of their superiority but found that my supplier had sold out and could only offer me another make…..Bahco, made in Germany. It is sad to say and with great regret that I have to admit that the Bahco blades are imho better than the Eclipse by a good margin.
                                                      Mick
