John wildings great wheel skeleton clock
Home › Forums › Clocks and Scientific Instruments › John wildings great wheel skeleton clock
  • #3777
    Andrew Read 1
      @andrewread1
      Running problem
      #327387
      Andrew Read 1
        @andrewread1
        hi
        I'm in the process of completing the great wheel skeleton clock by John Wilding, the clock runs for 48 hours plus but then stops, I've looked at the pivots and gear meshing and all looks good. I'm going to make a new escapement in the hope that that may be the issue
        Would appreciate any thoughts please
        #327393
        roy entwistle
          @royentwistle24699
          How much looseness is there in the pivots. they shouldn't be too tight. If it runs for 48 hours it shouldn't be too bad .
          Check the great wheel teeth and the centre pinion when it stops
          Roy
          #327397
          Bob Stevenson
            @bobstevenson13909
            When you hold the clock flat on it's back you should hear a distinct 'click' when you turn it over, which will be the arbours dropping back with their endshake…… Also, be aware that the pendulum on that clock is suspended on silk thread….this is vital that it actually is silk as the effeiciency of the silk is much greater than other thread materials.
            #327626
            Andrew Read 1
              @andrewread1
              Thanks for the help and will look at the suggestions you have made
              #327687
              peter ravenscroft
                @peterravenscroft57700
                have you seen the series on you tube about building the great wheel clock it is in about 24 parts good viewing
                search for clickspring it may help you as it is very detailed
                regrads
                peter
