Jobbing Engineering Shop Recommendations – Berks area
Home › Forums › Help and Assistance! (Offered or Wanted) › Jobbing Engineering Shop Recommendations – Berks area
  • #615599
    Andrew Phillips 4
      @andrewphillips4
      Hi All, I am modifying a BSA 8 inch front brake drum to fit a 'special' and it is too big to swing on my Super 7. I used a local engineering workshop but despite giving them photos and drawings they took weeks to do an incomplete job. Can anyone recommend a small engineering workshop in the Wokingham/Berks area to finish the job? Andrew
      Edited By Andrew Phillips 4 on 30/09/2022 20:03:12
      #34087
      Andrew Phillips 4
        @andrewphillips4
        Turning 8 in brake drum
        #615600
        Michael Cox 1
          @michaelcox1
          Try Tak Engineering on Slough Trading Estate.
          #615622
          not done it yet
            @notdoneityet
            Would it not be better, and cheaper, to join your local model engineering society? Presumably the wheel centre is not attached to the rim?🙂
            #615624
              Posted by not done it yet on 01/10/2022 05:59:33:
              dont know … choose the right “jobbing workshop” and it wouldn’t matter anyway.
              Brian Wood
                @brianwood45127
                Andrew,
                Check your inbox, you have two PMs
                Regards Brian
                #615660
                UncouthJ
                  @uncouthj
                  Classic & Modern behind GT Holland's shops in Bracknell?
