Hi all,
I have a small screw-cutting lathe (similar-ish to an ML7, without the gearbox) and I've been pondering how to improve accuracy, repeat-ability & simplify screw-cutting. Specifically, how to automatically stop the saddle at a the same point on multiple passes.
I did a fair bit of research and have found numerous references & articles talking about de-coupling the change gears from the tumbler with a single-tooth dog clutch.
As far as I can see, the primary facility that these dog-clutch assemblies offer is the ability to dis-engage & re-engage the timing gears while the motor is running. The point (assume) being that the dog tooth in the clutch assembly is stronger than the gear teeth, and is therefore un/less likely to break when the gears are re-engage, while the motor is running…?
So…to my (potentially bad?) idea…
My requirement is to be able to automatically dis-engage the timing gears only. I'm happy to re-set things manually. As such, I wonder if I even need to add a dog-clutch assembly?….Could I just add a trigger to disengage the existing tumbler mechanism at a repeatable point each pass?
I guess the bottom line is this: while I appreciate that there is a risk of damage if the tumbler gears are engaged with the lathe spindle turning, is there a similar risk when dis-engaging them with the lathe spindle turning?
BTW – the reason for this train of thought is that the shaft that the tumbler output gear & the timing gear chain input gear is 1) very short – about 3 gear-widths long and 2) acts as the pivot for the tumbler-actuation lever.
I'm sure I could design something to fit, but it occurred to me that there might be a simpler approach
Any thoughts, much appreciated!
cheers
Paul
