Interesting parting off technique…
Home › Forums › The Tea Room › Interesting parting off technique…
  • #692644
    Andy Stopford
      @andystopford50521
      …and a long-suffering DSG lathe:
      https://www.youtube.com/watch?v=8yQrfDFKG_k
      #692645
      Rainbows
        @rainbows
        Take note of the hard working live centre at 6:00
        #692712
        Nigel Graham 2
          @nigelgraham2
          Amazing skill, it said….
          Thick and Useless Iron, it said….
          Iron is not noted for being bright, but actually the screw material looked quite decent steel, while the cast-iron for the nut appeared of the aerated grade to reduce weight.
          I thought my workshop was untidy and material stocks of the come-in-handy variety!
          Note the lack of trip-hazards so as not to catch the safety-sandal shod workmen, the air-cooling system for the motor and belts driving the planing-machine, and the type-approved V-profile lifting-sling. At one point we see a man using an off-hand grinder in the background – I think he was wearing contact safety-glasses.
          Also the little chuck-clearance rebates carefully machined in the lathe’s tool-post.
          The chap in the brown robe a seemed the more patient and skilled of the two, but had he not heard of using a saw to cut that last bit of the “parting off”?
          To be fair to them, they were doing their best with ancient machines quite likely knackered before they arrived there, very pre-loved materials Grade ‘Enniold’, and in very poor working conditions in a ruinous building (does it have a roof? – and I have seen worse cruelty to a lathe.
          In this country.
          One Dean, Smith & Grace lathe of similar size to that, alongside a Bridgeport turret-mill, static at the time but obviously both used for machining architectural components in….
          …… sandstone.
          #692789
          Martin Connelly
            @martinconnelly55370
            When labour is cheap and easy to find and there are no consequences for the employer if an employee is killed or injured this is what you get.
            Martin C
