Indexable Chamfer Cutter – too much choice
Home › Forums › Workshop Tools and Tooling › Indexable Chamfer Cutter – too much choice
  • #509665
    Lee Jones 6
      @leejones6
      Just searching one of my usual places for picking up indexable tooling.
      Looking for an indexable chamfer cutter this time around.
      Stumbled over Link removed see CofC seller and was blown away by the choice.
      Despite the obvious diameter/angle differences, why would you choose one of these styles over the other?
      I'm particularly interested in the rectangle (APMT) vs triangle (TCMT) variants.
      Edited By JasonB on 24/11/2020 20:12:29
      #20042
      Lee Jones 6
        @leejones6
        #509667
          Single triangle will usually go down to a smaller size hole or radius
          Square can often be used above and below the work without changing tool
          2 or 3 insert allow faster feed rates for same given chip load over single insert but minimum radius goes up.
          #509668
            Hass explain it quite well in this video
            #509669
            Lee Jones 6
              @leejones6
              That's what's confusing me the most, both S and T have the same min-radius.
              #509670
              old mart
                @oldmart
                I've got one that is adjustable for angle.
                #509671
                Lee Jones 6
                  @leejones6
                  Oooo, posh. How does that work?
                  #509674
                    Lee Jones 6
                      @leejones6
                      A (moving) picture paints a thousand works. Thanks a bunch. yes
                      #509680
                      old mart
                        @oldmart
                        I can't post a pic of the adjustable chamfer tool as it is locked up at the museum at the moment. It is a WNT and the single sided positive insert sits in a holder that pivots around the central hole in the insert. SAU also make the same type. Some use triangular inserts, and some square ones.
                        #509682
                          An insert for an insert …That’s neat.
