Posted by Paul Kemp on 10/03/2019 23:39:31:
Lee,
Dont be put off lol. It seems like this topic in some form comes up a couple of times a month and it's not unreasonable to expect it will continue to do so. If you have not had a lathe or mill before, buying one to most people represents a significant expenditure so they want to get it right. Sadly though therein lies the problem, what is right for me may not be at all right to you! By the very nature of people they will likely give answers based on what is right for them based on their experience good and bad doing what may be a million miles away from what you envisage doing. Andrew's point about size is a fair one, if you want to make watches you don't want a Colchester and a Bridgeport! So a fair few will answer a vague question with another – what do you want to do?
FWIW I think given you don't know what you want to make, your mentioned choices of machine are not bad and will give you plenty of scope to find out (as long as you don't end up deciding you wanted to make a watch!). I was considering a Warco mill myself, as it happens I managed to get an old British machine which now I have it I am very happy with, appreciate its versatility of horizontal spindle and vertical head in one machine and I now realise I would have been frustrated by the Warco. But that is just me for my particular interest and I wouldn't spend time trying to convince you that you should do the same! It sounds like you have done some research and come up with a workable plan, so if you are happy with that, go for it.
Sadly I fear even if you had pitched your question in a different way and listed the machines you have identified from the start there would still have been negative comments, sucking of breath through teeth and comments "ohh I wouldn't buy one of those"! It's just a no win situation. Only caution I would sound if buying a Colchester is hear it running, bearings and headstock guts are expensive and try and make sure it has not been used in production for 20 years with the associated bed and slide wear. Other than that, go for it, you won't know really if they are right for you until you have them and use them! I have been using machine tools for 40 years on and off and even a poor one can turn out reasonable work if you know what you are about.
Paul.
Thanks for that Paul, very informative. I would certainly like to enjoy a nice old British (or similar build construction) machine. However with my current level of knowledge (low) and naivety (high – I do not even know what I do not yet know) I am highly concerned about buying a "dog" and regretting the whole ordeal.
Rebuilding or regrinding these machines myself is certainly not in my current skill-set.
Posted by JasonB on 11/03/2019 07:33:03:
Posted by Lee Jones 6 on 10/03/2019 20:43:54:
Perhaps it would help if I provided you with the machines currently as the top of my list (I should add at this point that, as much as I don't want to go reinvigorate any 'new vs old' flame wars, I would be happy to take suggestions for either): Lathe wise my two top choices are either a second hand Colchester Student, if I can find one from a source that I can trust or a Warco WM250 (£1625.00). On the milling machine side I've been hovering around the Warco VMC (£1932.00), which would leave me with nearly £2k for accessories.
An interesting short list given your earlier statement about wanting to make larger things.
Although the VMC is physically larger than the typical bench top "model" mills it has about the same capacity than something like an X3 give or take 10mm so you are not really going to be able to do anything larger on it.
Likewise there is a big difference between a student and a WM250, for larger work I would have said at least the GH1230 would be what you should be looking at if you want Student capacity.
If you do want a Student size lathe and a matching size mill then I think your only route with that budget will be to go down the second hand route as you won't get two new machines in that size range for the money let alone anything to go with them.
J
Jason, my naivety showing though again I think. When I said larger, I was alluding to larger than what I perceive model making to require. Certainly not Abom74 large in any case. From what I have seen when watching my favourite hobby machinists at work, a Colchester Student and a Bridgeport would be wonderful. However, I remember reading somewhere (this forum perhaps?) that for a beginner such as myself it would be better to go for a new import from a reputable dealer/importer than to roll the dice on a second hand machine from the 1960s for example.
The trouble is; I don't know anyone who either owns a machine like this or knows anything about them. Thus any knowledge I acquire has to come from online resources and books. Nougats like "… if buying a Colchester is hear it running, bearings and headstock guts are expensive …" are invaluable to myself and people in my position.
