Identification Please, anyone!
Home › Forums › Workshop Tools and Tooling › Identification Please, anyone!
  • #326915
    Noel Rieusset
      @noelrieusset48142
      rotary table 280 dia e.jpgrotary table 280 dia d.jpgrotary table 280 dia c.jpgrotary table 280 dia b.jpgIt does not have a name stamp, perhaps it came with a milling machine.
      This is what I have
      What I know is it came from the then "West Germany"
      It was owned by an Instrument Maker / Toolmaker now deceased.
      The only stamping is the number 618 shown in the photo.
      I believe it is old but don’t know how old.
      The black round handle and crank handle are black bakalite.
      When was bakalite last used????
      The table is 280 mm in diameter. with 4 x 4 slots 14 mm.
      The wheel and pinion are hardened and ground and sit in an oil bath, the level of which is indicated by a glass tube sight glass.
      All screws are machine cut, as are all the screw slots which are milled.
      The filler cap screw has a tiny air hole and is a beautiful piece of engineering.
      A number 3 Morse (I think) taper in the center.
      The graduations are cut, and numbers are all stamped.
      The dial on the winder is in three sections of 0 to 100.
      The ratio of the table is 120 : 1
      Small parts Nickel plated
      The only thing missing is the "0" or verier scale, I do not know which, but because of the length of the area where it was (See photo) I think it may hace been a vernier scale.
      Words on the bakelite handle are "NICAFIL 1761/1" very small about 1 mm high.
      Any clue at all would be great please.
      #18741
      Noel Rieusset
        @noelrieusset48142
        #326996
        Tim Stevens
          @timstevens64731
          Bakelite is still used. The recipe has been tweaked over the years, but for things like electric junction boxes, plugs, etc, which need to be rigid not flexible and fairly heatproof, it is still a common choice. Think of car distributors, too.
          It can help when dating stuff to look for chromium plate – introduced about 1929. That said, nickel was still in use for engineering (rather than outside) stuff until much more recently. But I can't see any of either of these … However, as a different clue, West Germany did not exist until just after WW2, and went back to Germany about 1990.
          What you have looks to me like a quality product, perhaps intended originally as an 'extra' for a specific milling machine. There are alternative tapers which you should investigate (such as Brown & Sharpe, common with US stuff), before you invest in further tooling to use with it.
          Not much help, really, am I?
          Regards, Tim
          #326998
          Emgee
            @emgee
            Perhaps from Hoffman, the coolant lip looks familiar.
            Emgee
            Edited By Emgee on 13/11/2017 18:43:17
            #327001
            mark smith 20
              @marksmith20
              I think it is a Schaublin, if so it will be nice . The style and handle is instantly recognisable.
              heres its smaller brother:
              Edited By mark smith 20 on 13/11/2017 19:14:53
              Edited By mark smith 20 on 13/11/2017 19:17:56
              #327002
              larry Phelan
                @larryphelan54019
                Not sure what it is,but it looks like a nice bit of equipment, better than most of the crap on offer these days.
                #327021
                vintagengineer
                  @vintagengineer
                  It looks very much like a Deckel rotary table for a Deckel milling machine. Will also fit an Alexander mill. Are you selling it ?
                  The number stamped on it will match the number of the mill it came from.
                  #327025
                  Bikepete
                    @bikepete
                    I'm fairly certain it's a rotary table for a Schaublin 53 or 53N: scroll down a bit for pics at:
                    http://www.lathes.co.uk/schaublinmiller/page4.html
                    and
                    http://www.lathes.co.uk/schaublin-53N/
                    I have a 53N: if you ever want to sell, or perhaps swap for a slightly smaller Hoffmann rotary table, please let me know!
                    Edited By Bikepete on 13/11/2017 21:56:21
                    #327209
                    Noel Rieusset
                      @noelrieusset48142
                      Thank you EVERYBODY.
                      It is defiantly a "Schaublin", everything matches, even down to the oil nipple position.
                      Thak you bikepete and Mark
