I section metal
I section metal
Home › Forums › General Questions › I section metal
  • #25692
    Eric Cox
      @ericcox50497
      #331675
      Eric Cox
        @ericcox50497
        Is small (1/4 – 6mm) I section metal available or will I have to machine it out of square bar.
        #331677
        Ady1
          @ady1
          Is it 1mm thick?
          If its 2mm then its a block with a groove, 2+2+2=6
          #331683
            Try Eileen's Emporium or knupher
            Edited By JasonB on 12/12/2017 09:58:20
            #331684
              If the exact section isn't critical, buy small u-section and soft solder two pieces back to back.
              Eric Cox
                @ericcox50497
                Thanks Jason, Eileen's appears to be the dogs.
                #331701
                ken king, King Design
                  @kenkingkingdesign
                  Eric, you didn't specify a material, but I have seen Brass in I section, along with Tee and Angle in several model shops, but Eileen's does seem a good source, and one I didn't previously know of, so thanks for that,
                  Ken
