Had my new Sieg KX3 and stand and other necessary bits all delivered from Arc Euro two weeks ago (only a week after ordering). I initially removed all the outside casing and installed the stand and built the PC the next weekend weekend, but left the mill sat on its pallet. This Sunday I borrowed an engine hoist and got the mill up onto the stand and bolted down, cleaned up (not a lot of shipping gunge to remove actually), connected up PC and got ready for initial setup.
I was ready to test it out late Sunday night. Had a quick try using the Jog function using the Up/Down, Left/Right and Page Up/Page Down keys on the keyboard and the Z axis goes up and down, and faster with the Shift key held down, Y Axis moved back and forward and faster with the Shift key held down, but the X axis does not move (but there was a change in the ‘hissing’ sound from the controller and the DRO displayed it as moving), but it did move OK at full speed with the Shift key pressed, but the spindle did not spin up at all when started, so there was a bit of setup to go through. It was now 23:20 and time to retire.
Next step was to go through the setup FACs made available by John Stevenson on the smallcncsupport site, and hopefully get it all sorted and ready to run!
I managed to get out to the workshop last night for an hour and went throught the FAQs re machine setup. All the issues now resolved, everything working, table and head all now move in correct direction (all three needed reversing) and all jog slow and fast with the shift key now the motor tuning numbers have been corrected and the step pulse width has been upped to 5 (some were 2). All three stop at limits and jog off after Reset hit (previously had to power off mill and wind the X axis off the switch and then power back on).
A quick distance move check looks OK but was not accurately done, I just wanted to see if it was close or way out, it is close and hopefully bang on!
I need to determine if spindle RPM is correct…. need to find a tach that will help here, but so far all is looking promising.
Thank you John for your FAQs and documented assistence here; without which initial setup would probably be a bit of a nighmare!
So far I think I have made a good decision to go with this set-up.
