Hypollergenic sealants
Home › Forums › The Tea Room › Hypollergenic sealants
  • #701846
    Iain Downs
      @iaindowns78295
      This will be an-off-the-topic post even for the tea-room.  However, I have a very odd question and in my experience there’s a representative of just about any subject known to man somewhere on this forum!
      The background is this.  My brother-in-law has sinus problems which are environmental.  He gets quite unwell and in the previous house he shared with my sister, was troubled most of the time.  Probably damp/mould related, but he also suffered when new (real new not just new to him) soft furnishings were brought into the house.  Some of the modern fabric / wood treatments probably.
      Now they’ve moved house and things have improved a lot but he is still suffering in the kitchen, though the rest of the house seems OK.  the kitchen is in a newish extension and their working theory is that it is the MDF of the worktop (one of those laminate ones) which is the problem, made worse as some of it has been affected by steam / condensation and has started to weetabix.
      Finally, my question!  What can we use to seal the underside of the worktop which will stop any outgassing and which is not likely to add any other risky fumes to the room.
      Any other suggestions for possible causes would be welcome as well.
      Looking forward to the replies.
      Iain
      #701881
      Journeyman
        @journeyman
        Might be worth trying a water based acrylic varnish. No real volatiles to off-gas but it does have an odour until dry. Once dry seems to be odour free. Two coats should adequately seal MDF or chipboard. I have used plenty on various projects possibly not quite as hard wearing as a polyurethane product but under a worktop should not be a problem.
        I find that many printed items seem to give off unpleasant fumes. Many of the circulars that drop through the letter box are consigned directly to the re-cycling bin outside for this reason.
        bernard towers
          @bernardtowers37738
          Chipboard is reputed to give off a gas for the first few years of its life, cant remember which gas but I’m sure it’s on the net somewhere. Just came to me I think it’s Formic acid.
          #702138
          Dick H
            @dickh
            Unless the worktop is something special it is probably chipboard bonded with melamine formaldehyde binder, similar resins are used to bond the decorative paper to the sides Most of the outgassing is from the core. Usually when kitchens are put together the ends of the laminate are sealed either with silicone or an iron on or glued type sheet. Formaldehyde is a small molecule and escapes easily. If your brother has access to a air filter (room pollen filter type devices” with an activated carbon filter running this might help but there is so much else going on in a kitchen is might saturate fairly quickly but might help identify the problem,  else that the laminate “weetabix”s, it could also harbour mould. Check for other leaks that could case hidden mould.
            #702145
            Russell Eberhardt
              @russelleberhardt48058
              Formaldehyde (not formic acid which is the defense mechanism of ants) is given off by the resin holding the chipboard together.  It gets worse in damp conditions which cause the resin to deteriorate.  I presume what you refer to as “weetabixing” is caused by damp.  The first thing to do is fix the damp not try to seal it in.  The damp may be caused by leaks, spillages, poor ventilation etc.  Sealing the underside may make it worse by sealing the damp in – it needs to dry out.  Formaldehyde, being a small molecule will not be trapped by varnish.
              Russell
              #702367
              Iain Downs
                @iaindowns78295
                Thanks for all your input.
                I’ve fed it back to my brother-in-law.
                Iain
                #702386
                John Haine
                  @johnhaine32865
                  They are probably chipboard not MDF, however both use I think a formaldehyde resin which is quite nasty stuff.  If it’s already damp then probably needs replacing, however may be recoverable using Ronseal wet rot hardener which I’ve found very useful.
