Hi Roger ,
Engineering method is to heat the spring using an electrical current passed through the actual spring .
Very little current needed for such a tiny thing so small battery plus rheostat should do it .
Safer not to use anything mains powered and no need anyway .
Experiment on scrap first to get idea of current needed .
For actual job increase current gradually from very low until required redness colour is seen .
Maintain current whilst quenching thus metal hits coolant at exactly right temperature without undesired cooling off in transit . Turn off current while spring still immersed .
Optionally play small flow of safe inert gas over top of coolant pot and do heating of spring in place so as to exclude air throughout .
No air and no flame should mean no scaling at all .
Temper if needs be using same method .
Also works for small tools using higher currents and can be applied selectively to zones within workpiece .
Regards ,
MikeW
Edited By MICHAEL WILLIAMS on 01/01/2014 14:52:04
