Hinge Straps
Hinge Straps
Home Forums General Questions Hinge Straps
  • #301480
    David Haynes
      @davidhaynes53962
      Is there any reason why brass should not be used for smokebox door hinge straps? Some materials must not be used, such as aluminium, as the heat might affect it, but what do others prefer?
      David Haynes
        @davidhaynes53962
        What material for hinge straps
        #301486
        IanT
          @iant
          Well I just use mild steel David – but some prefer stainless for obvious reasons.
          However, I don't see why you shouldn't use brass – apart of course from the issue of it's colour (if unpainted) and/or (if painted) the fact that it doesn't take paint as well and if it does get 'chipped', then you get to see the brass showing through…
          Mainly a matter of personal preference I suspect…
          IanT
          #301562
          Ian S C
            @iansc
            I would say it depends on what the smokebox door is made of, if a brass casting, use brass, if cast iron, or steel, use steel.
            Ian S C
            #301565
            richardandtracy
              @richardandtracy
              On the 2 LBSC designs I can remember, I think he suggested brass. (Mable Hall was one of them & mind's gone blank on the other)
              OK, they were both 2.5" gauge and people may feel differently about different gauges.
              Richard.
              #302076
              Peter Maloney
                @petermaloney70994
                Not directly related, but a good source of small hinges when cut up can be found on spec cases. Especially good for Pansy tool box hinges.
                Peter
