Just a thought or two on LED lighting. I spent some time in the lighting industry and also did development work on LEDs at the beginning (40 odd years ago).
The one thing that some LED manufacturers don't tell you, is that the quoted lifetime of LED lighting refers to the lifetime of individual LEDs tested as individual units.
Now LED lifetime is critically dependent on temperature, so if you have LEDs in a group. Then the local temperature rises and down goes the LED life.
For example if you have an LED replacement bulb (like the old household lamp) and you put this in say a lamp shade that has no means of convection, then the bulb life is critically compromised. I have such reflectors and major brand LED light bulbs do no better than 1000 hours lifetime.
I have changed over to LED lighting and would not go back to GLS or compact fluorescent lamps. But beware of the smooth sales talk of the lighting manufacturers. You MUST keep the local temperature down otherwise the lifetimes are much reduced.
Andrew.
