Hey guys help me please – Boxford ID
Home › Forums › Help and Assistance! (Offered or Wanted) › Hey guys help me please – Boxford ID
  • This topic has 12 replies, 7 voices, and was last updated 3 June 2017 at 10:29 by Vincent Marzetti-cooke.
  • #300533
      @vincentmarzetti-cooke95920
      Can anybody tell me what model boxford this is please.
      #32989
        #300636
        Rex Hanman
          @rexhanman57403
          I can't see power feed/cross feed controls or a screw cutting gearbox. Therefore I reckon it's a model C.
          See here……
          http://www.lathes.co.uk/boxford/page2.html
          #300770
          Robbo
            @robbo
            Boxford C spec.
            #300787
            Marcus Bowman
              @marcusbowman28936
              Looks like a C to me. Lathes.co.uk says 'A (gearbox and power feeds), B (changewheels with power feeds) and C (changewheels and hand-cross feed) ' and that accords with my own experience.
              The leadscrew engagement handle also tells you something about the age (black plastic on the much later models), as does the position of the backgear change handle (top of the headstock on much later models). The thickness of the base of the cross-slide indicates whether the lathe is 4.5inch or 5inch centre height.
              Serial number (often at the right hand end of the bed, stamped into the front bed way, should also tell you (at least on the underdrive machines, but I imagine on the others too).
              There are different bed lengths.
              Marcus
              #300800
              Speedy Builder5
                @speedybuilder5
                Oops – beaten to the same question – serial number
                Edited By Speedy Builder5 on 02/06/2017 08:52:34
                #300813
                  looks like it is a model b from the pictures. Found this on the end of the bed.
                  #300822
                    Nope is a model c, has a new motor, and it is turning clockwise.
                    #300835
                    Speedy Builder5
                      @speedybuilder5
                      Turning clockwise – That's in reverse then ?
                      #300841
                      Muzzer
                        @muzzer
                        You can "reverse" the machine by standing at the other end of the spindle
                        #300857
                          Yep I think it is, think I shall just change the wiring to the motor.
                          #300866
                          Niels Abildgaard
                            @nielsabildgaard33719
                            It is ,I think ,a long bed C.
                            Is there a full set of change wheels?
                            #300951
                              Yes I got some with it, about 8 different cogs of various sizes.
