Help needed Purley Grange
Home › Forums › Locomotives › Help needed Purley Grange
  • #360707
    Raymond Hodges
      @raymondhodges20973
      I started building the Purley Grange from LBSC in 2½" gauge in 2014. I have run it on air and have found the following problem.
      In forward it runs on 4 bar quite good but in reverse, on the same presure it runs very fast.
      Can someone tell me where i am going wrong.
      Thank you
      Ray
      #1734
      Raymond Hodges
        @raymondhodges20973
        #360949
        Jeff Dayman
          @jeffdayman43397
          Hi Ray
          I have not built your particular locomotive, but the problem sounds to me like it may be due to unequal valve movements forward vs reverse. Is your reverse stand in the right position? If you use a dial indicator to measure the valve movements all the way forward then all the way back, are these movements the same distance each way when reverser is in mid gear?
          Might also be due to your valves' position on the spindles, or possibly your valve port positions are a bit off. Either way the valve adjustment can probably adjust the working to give more equal events or at least faster forward speed.
          #360981
          Raymond Hodges
            @raymondhodges20973
            Thank you Geoff
            It seams i need to do a few checks, now i know where to start.
            Its easy to make the parts but not so easy to get them to work together
            Ray
          Home › Forums › Locomotives › Topics
