Help choosing my lathe
Home Forums General Questions Help choosing my lathe
Viewing 25 posts - 1 through 25 (of 43 total)
  • #448254
    Swarfy
      @swarfy
      Hi
      I’m about to buy a lathe and after deliberating for days I think I’m settled on the warco 250v now I’m 67 years old and have been a precision engineer since I was 15 I served my apprenticeship at MK electrics in Southend then after that a plugboard setter at a local engineers for 30 years then a CNC programmer setter running my own shop working on everything from automotive ,medical, aerospace motor sport etc .i did spend a few years machining high pressure fittings for oil and gas which were mainly American imperial sizes
      my question is the lathe I want is only available at the moment in imperial metric will be available mid feb ,now I’m not bothered about the wait but do I get the imperial model it does both threads anyway and I still think in thous my mics are imperial although I have metric as well so not a big problem just I’m inches man ! Can anyone see a problem me getting imperial or should I wait and get modern and go mm any advice one way or the other would be appreciated
      cheers mick
      Swarfy
        @swarfy
        #448255
        Nick M0NPH
          @nickm0nph
          If you have / get a DRO fitted it wont matter as that will work in both
          just an idea
          #448258
          Swarfy
            @swarfy
            Posted by Nick M0NPH on 22/01/2020 17:41:04:
            just an idea
            Trouble is that’s more £s and the wife only just agreed to the stand to go with it ,
            #448262
            Brian H
              @brianh50089
              If you'r more at home with Imperial then I'd go for that. If a metric job comes along then there's always the calculator.
              You could always fit the DRO at a later date, when your wife has forgotten about it.
              #448266
              Former Member
                @formermember19781
                #448268
                Swarfy
                  @swarfy
                  Posted by Brian H on 22/01/2020 17:57:30:
                  When I was working I always had 25.4 and .03937 programmed into the calculators memory
                  #448274
                  Nigel McBurney 1
                    @nigelmcburney1
                    I am a bit older than you and trained on imperial machine tools , after early retirement 25 years ago I expanded my workshop from an imperial myford s7,a fobco drill ,and an old round head Colchester, I then in addition aquired an all metric Colchester triumph ,and a Colchester master with dual dials, plus an imperial turret mill I have a good selection of micrometers imp and metric and a lot of other mixed equipment ,at my last job I pushed a desk and the company changed over to metric.,and i got on well with metric drawings and measurement After retirement I I took on a few jobs ,a mix of imperial and metric and I found I was far quicker on an imperial machine,and one time I was very tempted to convert the triumph cross slide to imperial. so I would buy an imperial lathe particularly if you have the imperial micrometers etc..I have never been tempted to buy a dro ,electronics always seem to play up,and get in the way if machine capacity is pushed to the limit. I would go with what you are used to though in future a metric machine may be more saleable,though at the moment the hobby trade new and used sells both types,
                    I rarely use the metric dials on my dual dial Master 2500
                    #448277
                    Ian Johnson 1
                      @ianjohnson1
                      If you are used to imperial get the imperial lathe. I've got an imperial mini lathe with dials reading 0.001" & 0.025mm per graduation, any error is not worth worrying about, and the final dimensions and finishing cuts will be measured anyway so with a bit of experience you will know how much to turn the dial.
                      My little milling machine is metric with dials only reading 0.025mm.
                      Six of one half a dozen of the other.
                      Good choice of lathe by the way, the 250V is a versatile machine, I was looking at the Chester DB10 which is similar.
                      Ian
                      #448292
                      Swarfy
                        @swarfy
                        Thanks for your replies im erring towards metric as the resale value on imperial might be affected dont get me wrong i had 5 cnc machines and all but one were programed by me in metric the hardinge lathe i kept imperial as that was my first machine and all my jobs at the start were imperial pipe fittings
                        Mick
                        #448309
                          Hi Swarfy,
                          It really depends on what you want to make.
                          If you make model steam engines from old plans dimensioned in inches of scled from imperial sizes,imperial is easiest.
                          If you are making things to go with modern metric parts, then metric.
                          If you make your own stuff, whatever you enjoy using most.
                          Don't worry about resale, at that level it makes little difference and a few quid each way is nothing compared to the convenience of having a machine you are comfortable with.
                          Philip Powell
                            @philippowell34749
                            Mick. Have you considered if the leadscrew is different in metric or imperial machines? You might find one has a more useful range of thread pitches or tpi than the other.
                            When I did my apprenticeship in 1975 to 1979 everything was imperial. I soon left engineering to work in IT and returned to engineering as a machinist in 2010, what a shock, everything had gone metric, drawings are third angle projection, machines are nearly all CNC or if manual have a DRO. But I much prefer to work in metric, everything is much more logical no messing about with fractions or number/letter drills etc. Oops! Opened a can of worms there.
                            Phil.
                            #448317
                            Former Member
                              @formermember19781
                              #448319
                                Posted by Philip Powell on 22/01/2020 20:58:58:
                                … or perhaps millipedes devil
                                Vic
                                  @vic
                                  Posted by Neil Wyatt on 22/01/2020 20:53:48:
                                  Hi Swarfy,
                                  Yes, good advice.
                                  I’m a bit younger and much prefer inches for woodwork and metric for metalwork! laugh
                                  #448328
                                  not done it yet
                                    @notdoneityet
                                    I’m metricated but have used umpteen (it feels like) scientific measurement systems, so imperial is easy. My lathe and larger mill are imperial and the smaller mill is metric. I nearly always measure in metric unless I am using my limited range of micrometers – some imperial and some metric – but I nearly always aim for a metric size. 0.01mm target is more than close enough for most things I do and 0.04mm would usually be perfectly adequate.
                                    As more and more goes metric, buying new would be a no-brainer for me. Long threads will be correct, with no approximations for the metric machine. Fewer and fewer imperial threads will be used as time progresses. DRO’s certainly take away those calculations, but I still find it easier to add cut by the turn of the handle for roughing cuts.
                                    Gear cutting is similar – most of mine, because they are ancient machines, are DP – in that MOD will eventually take over. Depth of cut, if the gear is to be cut in one go, is currently imperial but eventually will be metric only.
                                    Think here your old housing stock. 15mm copper pipe is the same as 1/2” but the rest need converters every time the pipes are altered.  Bricks are metric.  Everything is metric like large sheets of ply.  Think vehicles – they are all metric now.
                                    Yes, metric is so much easier than imperial measurements. The only ones out of step are the Americans.
                                    Edited By not done it yet on 22/01/2020 22:06:17
                                    #448341
                                    noel shelley
                                      @noelshelley55608
                                      NDIY, is not a plumber or he would know that 15mm most certainly is not 1/2" Nor does he work with RSJs etc where the size may be expressed in metric but is really inperial. The imperial system is far more used the world over than most realise. My apprenticeship was in the days of feet and inches but I use both systems. I would lean to an imperial machine ! Good Luck Noel.
                                      #448344
                                      Ian Johnson 1
                                        @ianjohnson1
                                        I only buy metric milling cutters for my metric milling machine nowadays. I've got loads of 3.175mm cutters which fit quite nicely in a 1/8" end mill holder laugh
                                        #448347
                                          Posted by not done it yet on 22/01/2020 22:04:13:
                                          dont know
                                          I wonder why they make a special ‘Slip Adapter Coupling’ then
                                          https://www.pegleryorkshire.co.uk/MEDIA/Downloads/CC_004/61632585_Yorkshire_Solder_Ring_Fittings.pdf
                                          not done it yet
                                            @notdoneityet
                                            Posted by Michael Gilligan on 23/01/2020 00:14:29
                                            dont know
                                            I have never made a 15mm/1/2” copper coupling with a “special’ connector, but I do know that 1/2” is 12.7mm, not 15😉. They are close enough, for a solder joint, to be compatible. 3/4”, and above, are a different story. You carry on paying out for the expensive connectors and I will carry on just as I have for the last thirty years, and I will also continue with the generalisations. Most sheet material is now 2400 x 1200mm – steadily changing from 2420 x 1210mm. Builders build at 400mm centres for roofing, etc, not 16” as they used to do. I’ve not come across a double glazing company still using inches for manufacturing details – perhaps you know different? No imperial gas meters are installed these days? – even though my supplier seems to take my metric meter readings as though they a cu ft – but charge me by the cubic metre.🙂
                                            They likely make these expensive couplings for people like you to purchase?
                                            I am aware that threaded pipe connectors are BSP – virtually worldwide. But get real, metric is here and here to stay. Some luddites will continue to use imperial units (I meaning beyond the generation that ‘grew up in that era&rsquo. That era has gone. Schools do not teach in imperial units (although converting to old units is part of the syllabus, still).
                                            Yet some students only know their height and weight in imperial numbers – many unaware of manipulating those units mathematically. But these are becoming fewer, thankfully.
                                            As someone from that era when imperial units were rife – but metric scientific units were rapidly becoming universal – I know which system is the sensible one. The only other old unit still commonly used these days is likely calories – but that is still a metric unit (but not SI) – nobody but nobody uses British Thermal Units per ounce (as far as I know). Let us know if you do.🙂
                                            It’s like other things that have been standardised – like our domestic grid voltages – the same as the rest of Europe but not really quite the same. Yes, there will be odd-balls and some compromises (fudges) but metric is the sensible system and is steadily becoming more universal (apart from the Americans and some minor ‘buddies&rsquo.
                                            Have a nice day. Go and cut some imperial metal – if the sizes are easily available or only at a premium.🙂 Even woodworking has now virtually gone metric (softwoods have been traded in metric units for decades, but hardwoods have only mostly changed to metric dimensions much more recently (possibly that was to clarify, to some lesser mortals, which timber type they were using?&#128578.
                                            #448352
                                            Gerard O’Toole
                                              @gerardotoole60348
                                              Posted by not done it yet on 23/01/2020 05:54:14:
                                              I believe the 15mm pipe is 15mm outside diameter. The 1/2" pipe (1/2" inside diameter ) is 14.7mm outside diameter. So even less difference
                                              #448356
                                                Posted by not done it yet on 23/01/2020 05:54:14: Most sheet material is now 2400 x 1200mm – steadily changing from 2420 x 1210mm. Builders build at 400mm centres for roofing, etc, not 16” as they used to do.
                                                If only that were the case, plasterboard comes 1200 x 2400 and fits the 400mm spacing nicely but ply, osb, MDF, MFC comes in 1220 x 2440. or other multiples based on imperial
                                                It has never come in 1210 x 2420 but did used to come in 8 x 4 sheets which work out ate 1220 x 2440.
                                                #448370
                                                  Posted by Gerard O'Toole on 23/01/2020 06:50:09:
                                                  yes
                                                  … and you need a slightly stepped coupling to make a good capilliary-soldered joint.
                                                  [ perhaps they don’t use Yorkshire fittings in Lincolnshire ]
                                                  Edited By Michael Gilligan on 23/01/2020 08:49:12
                                                  #448371
                                                  not done it yet
                                                    @notdoneityet
                                                    Oops, sorry, yes 1220 x 2440. Such a long time since I bought any of that imperial/metric fudge! I’m neither a builder nor a plumber. But the principle is the same – they are progressively going metric.
                                                    #448376
                                                      Sorry to drag this even further away from the subject of lathes, but:
                                                      It will be a while before the electronics industry completely abandons 0.1” [2.54mm] spacing on boards and components.
