Hello from Norfolk
Hello from Norfolk
  • #40283
    Trevor Crossman 1
      @trevorcrossman1
      #343896
      Trevor Crossman 1
        @trevorcrossman1
        Hello to all,
        I've frequently lurked around the Forum to find information about machine or tool parts, and have usually seen an answer somewhere here. Now that I spend most of my workshop time 'playing with metals' instead of 'working with metals', I thought that I had better come out as an incurable swarf generator! Being self employed for the last 33 years of a 55 year work-life meant that the two activities were pretty well entwined, if a job didn't look interesting or challenging then I'd pass it up, but now that pensions will buy the daily crusts, it is time to press on with The Unfinished Projects​ of which there are more than enough! Loads of new things to try so I will be asking the vast collective knowledge for advice from time to time. Current machines are Boxford VSL, Emco FB2, Pollard Corona, TIG gear, H/V linisher,and all the usual electrical and hand tools that metal bashing needs.
        #343934
        Brian H
          @brianh50089
          Welcome to the forum Trevor, sounds like you are well equiped for any projects that come along. As you've already found, there is a wealth of knowledge and experience on here just for the asking.
          #343966
          OuBallie
            @ouballie
            Which part of Norfolk Trevor?
            Geoff – I'm in South on the border with Suffolk.
            #343975
            Trevor Crossman 1
              @trevorcrossman1
              Hi Geoff, lovely South Norfolk too, just west of Loddon.
              #343979
              Spurry
                @spurry
                Greetings too, from just south of Bunwell.
                Pete
                #343982
                Trevor Crossman 1
                  @trevorcrossman1
                  Thanks for the welcome Brian, yes I'm well equiped, or perhaps I should say that my workshop is!! It's not so much the want of new projects, it's the want of more play-time to get those that I have already started finished, but I'm sure that I'll get distracted along the way.
                  #343984
                  Trevor Crossman 1
                    @trevorcrossman1
                    Hi Pete,
                    I've often passed through Bunwell on my way to or from Old Buc. for one job or another though that would be just the through road, never been in the old village itself.
                    #344013
                      Posted by Trevor Crossman 1 on 01/03/2018 21:20:58:
                      Welcome Trevor,
                      Be careful – most of us go a bit pale when the 'UF' are mentioned…
                      Brian Baker 2
                        @brianbaker2
                        Welcome Trevor, Acle not so far away.
                        What is your area of interest?
                        regards
                        Edited By Brian Baker 1 on 02/03/2018 16:59:13
                        #344065
                        Trevor Crossman 1
                          @trevorcrossman1
                          Thanks for the welcome Neil, yes I suppose that I should be more careful and put up a warning before mentioning the 'unmentionable', there seem to be a few of us with more than one such item gathering dust, going rusty, getting dented, robbed for parts but not quite forgotten!
                          Trevor
                          #344197
                          OuBallie
                            @ouballie
                            Posted by Trevor Crossman 1 on 02/03/2018 11:47:55:
                            Diss, with icicles on guttering.
                            Icy but dripping
                            Geoff – First time I've seen these.
                            #344218
                            Trevor Crossman 1
                              @trevorcrossman1
                              Hi Brian,
                              Many years since I've been Acle way, not since I spent a boring time in one of those linear car-parks that appear from time to time between Yarmouth and Brundall!
                              Main interests are R/C aeromodel/boat modelling and motorcycles, a rider since 1960 and currently use a BMW K75. The major UfP that I have earlier alluded to is a model 9 cylinder radial that I have been building for the past thousand years. When I resurrect it perhaps I'll post a build thread.
                              Trevor
                              #344222
                              Trevor Crossman 1
                                @trevorcrossman1
                                Hi Geoff,
                                it must be warmer in the winter in Diss than down here just above sea level where there's often a bit of winter ice, but this is an ICICLE…………146 cms………………..apologies to all for the wrong orientation, this noobies not yet learned the editing process!dscf8464.jpg icicle.jpg
