The latest:
All measurements taken with a calibrated 0.01mm Oxford dti (is this accurate enough or so I need to dig out the 0.001mm?)
Lathe and bearings cold.
Starting from the front, having supplied artificial preload from the tailstock with a revolving centre:
Dti at 90 degrees to spindle, on very tip of spindle nose, no real measureable run out…needle hovers over 0 line.
Dti at 90 degrees to spindle, on camlock mounting diamete, no real measurable run out…needle hovers over 0 line.
Dti parallel to spindle bore, again, no measureable run out.
Fine needle movement is attributed to surface finish.
Very centre of spindle as previously said has eccentricity of 0.14mm, but this is attributed to the gearing splined onto the shaft…it cannot bend in the middle right?
Having removed the rear bearing cover, and mounting the dti as close to the bearing as is possible, again there is no real measureable run out, needle hovers over the 0 line within 0.01mm. This again is attributed to surface finish.
At the very very end of the spindle there is eccentricity of 0.01-0.015mm. As the spindle looks to only be turned, and not ground finished, I assume this to be just manufacturing tolerances, but would welcome another opinion.
With a no 3 morse taper parallel bar mounted into a 3-5 and then into the spindle bore and tapped into place with a nylon mallet, the tool post runs true to the bar, 0 measureable deflection, needle hovers over the 0 line. Likewise, when measured up close to the spindle 0 run out, when measured at the very tip of the bar, a very small amount of run out, but a few gentle taps with the nylon got it pretty much bang on to 0…
Frustratingly removing the tailstock preload did not allow the spindle to relax, so currently still measuring as I have said…
With all that said, I am 99.99% certain that the spindle is not distorted. Other opinions would again be greatly appreciated.
Nigel has mentioned that some dealers load by stroping around the chuck. Ironically this was exactly how mine was loaded many years ago. Remember distinctly as thought at the time, that cannot be right, or why would they machine a purpose built threaded hole into the bed for a lifting eye…but at the time said nothing…that will not be the case ever again…
Bearing wise, and this is where I think I may have seen issues…
Looking into the rear bearing the needles are hollow, you can actually move the inner race between fingers…and when rotating the spindle you can see the needles rotate, and even move position…ie shift there axis…by inserting a drift into the bore of the needles it is possible to wiggle them left and right very very easily…I don't think thats right. Some of them actually drop just through gravity as they rotate past the TDC position through 45 degrees into 90 degrees rotation…so I am going out on a limb saying that the preload is way off…even though I cannot hear or feel anything wrong when turning the spindle. The heat being generated is possibly down to the front bearing having to have had to work a lot harder to remain concentric, which has led to premature wear.
I am going to endeavour this evening to take some footage of all said above to post for better passage of information…as pictures paint a thousand words.
As for the bronze looking bits in the oil…I cannot see any where they may have come from…but on the exploded diagram I have from a downloaded manual, there are some bushes on some of the gear shafts, which may well be bronze material but hidden from view till stripped out…Looked for evidence of contamination of the rear bearing but cannot see if any of this has made its way into the rear one to cause damage.
The saga continues…
As said, anyone near Exmouth on here that knows more than me?
