Hand held CNC Router!!!!
Viewing 15 posts - 1 through 15 (of 15 total)
  • #246688
    Involute Curve
      @involutecurve
      This is interesting, wish it showed the finished part though!!.
      Involute Curve
        @involutecurve
        #246689
        SteveM
          @stevem36008
          I agree – it was interesting!
          And here is the subsequent video showing the finished part
          *Finished Gear*
          #246693
          Ady1
            @ady1
            Looks just like a phone screen too. Nice to see new technology moving things forwards.
            #246701
            MW
              @mw27036
              weird.
              Edited By Michael Walters on 15/07/2016 13:31:08
              #246703
              KWIL
                @kwil
                Works "OK" on a light weight metal, how about something a little tougher?
                #246705
                  Posted by KWIL on 15/07/2016 13:53:33:
                  Works "OK" …
                  … in the words of Samuel Johnson:
                    Posted by Michael Gilligan on 15/07/2016 14:08:48:
                    Works "OK" …
                    A brief commentary:
                    frank brown
                      @frankbrown22225
                      Its a clever idea, I guess its based on the position moving mechanism of a mouse (~.004"/step). Just need a good start location. Like a right angle locator for its zero. it would be very useful for cutting the recesses for stair case treads. Looks as though the tool is a bit weedy as is the motor.
                      Frank
                      #246744
                      Enough!
                        @enough
                        What a conversation ….. it's all links.
                        Nearly as bad as wiki-type project documentation. (Nothing could actually be that bad).
                        smiley
                        #246746
                          Posted by Bandersnatch on 15/07/2016 22:03:22:
                          Wow !!
                          [Stands back in amazement]
                          HyperText being used in a web-based discussion.
                          … Whatever next ?
                          #246747
                          Enough!
                            @enough
                            Posted by Michael Gilligan on 15/07/2016 22:26:55:
                            … Whatever next ?
                            Actual words?
                            …. nah, it'll never catch on.
                            wink
                            #246750
                            Bazyle
                              @bazyle
                              It appears to use hand movement for bulk or long moves and localised detail is handled by a CNC move of the router relative to the main base. Somehow it combines the two. I would think staircase tread routing is a bit big for it to be an advantage but it would be useful for doing text and pattern engraving and inlays.. For inlays it should be able to to switch it from doing the recess and the insert.
                              I suppose I should look at their website but there is no link on this thread to that so I am at a loss as how to proceed. cheeky
                              #246751
                                Posted by Bazyle on 15/07/2016 23:11:12:
                                Hint : There is an address in the YouTube posting.
                                #246757
                                Mike Poole
                                  @mikepoole82104
                                  I would imagine the reference is from the dot matrix tape and a camera, so once you are happy that the cutter is at the start point the cnc will adjust the cutter as you move the base. could be useful for site work as you only need to stick the dot tape down and the you can route a complex hole or shape anywhere you like.
