Hammant & Morgan “MINIPACK”
Home Forums Electronics in the Workshop Hammant & Morgan “MINIPACK”
  • #792218
      I have no particular interest in model railway layouts, but curiosity got the better of me, and I bought this decrepit-looking controller from the Animal Rescue charity shop. [no mains plug, no PAT sticker]
      Hammant & Morgan were renowned for the build-quality of their controllers, so I thought it might be worth a look.
      Aside from the obvious signs of age, the worrying thing is the “handling” damage around the Resistance Selector. … [!]
      Having attached a Mains Plug, I was a little surprised to see a ‘No Load’ output of 32v on the terminals, but the reversing arrangement works fine.
      Having removed the control-knob, and drilled-out four small pop-rivets; I removed the top, and yes, the majority of the thing is nicely built … the exception being that Resistance Selector, which appears to be some sort of ‘lashed-up’ rotary switch with a flexible wire attached. … Why? one might ask!
      The order of assembly means that the details of its construction are not visible at the moment, but I intend to tear-down the whole unit … so they will be revealed in due course.
      Before I do, however … I would be grateful if someone ‘versed in the Art’ could explain the purpose, and modus operandi of this Resistance Selector
      … I presume it has something to do with the length/complexity of the track, but I have never seen it explained.
      IMG_0695
      Refhttps://www.binnsroad.co.uk/railways/handm/
      Bazyle
        @bazyle
        Your picture hasn’t worked MG.
        You haven’t mentioned if it is a modern solid state type or old wound resistance wire with a wiper contact running over it. The resistance selector just helped with locos that raced away too easily at the start. Possibly found useful with a mix of old inefficient motors (eg 1950 ) and modern ones from 1970.
        On two of my old controllers the selector just shorted out a section of the wound resistor track lowering the overall resistance.
        #792270
          Mmmm … Picture works for me, using the ‘phone as a hotspot in the Hospital CarPark.
          No transistors in the unit
          Appears to have a Selenium rectifier, but also has Brown & Blue mains wiring that appears to be original.
          Edit: __ Identified in the linked document as
          Hammant and Morgan Minipack (later, double insulated)
          #792353
          Grizzly bear
            @grizzlybear
            #792354
              Thanks … this could turn into an interesting little exploration.
