Guage Plate
Guage Plate
Home › Forums › Beginners questions › Guage Plate
  • #6319
    Deltic007
      @deltic007
      #97401
      Deltic007
        @deltic007
        Hi all,
        Any idea where i can get guage plate to make a motion bracket.
        I need 1/8 thick x 2 1/16 wide,everyone i have seen sells eithe 2" or 2 1/2 wide.
        Thanks 007
        #97402
        David Clark 13
          @davidclark13
          Why don't you buy 2 1/2 inch wide?
          That is wider than 2 1/16 and will do the job.
          What is the dimension the other way?
          regards david
          #97403
          Deltic007
            @deltic007
            About 1" long thats all
            Yes i would buy 2 1/2 who would you recommend to use?
            007
            #97404
            JohnF
              @johnf59703
              Hi Deltic,
              Any steel supplier will do or your local engineering supply house will probablyhave it available. Try the following links
              Look for "ground flat stock"
              If you PM me I might be able to find a small piece for you–I have quite a bit of it around and if you buy it you will have to buy a standard 16" length I think.
              Regards John
              #97405
              David Clark 13
                @davidclark13
                Hi There
                Why don't you buy 1 inch or 1 1/4 inch wide and cut it off 2 1/16 long?
                Try Blackgates, they might do it.
                I buy mine from J&L industrial as I have an account but they might be expensive on postage.
                Do you have a local engineers' supplies?
                regards David
                #97433
                DMB
                  @dmb
                  Hi Deltic,
                  I dont know your location, but if you live within easy travel distance, try Sussex Tools Ltd, which I have used in the past and found very helpful. The stock Gauge Plate, generally, but if not in stock will get requirement promptly.
                  203 Tarring Rd, Worthing West Sussex BN11 4HN. T=01903-216666.E= [email protected]
                  #97450
                  Sub Mandrel
                    @submandrel
                    Years go I bought some from Chronos, at that time they sold it in 2" by 6" pieces which keeps teh cost down.
                    Nicholas Farr
                      @nicholasfarr14254
                      Hi, you could try Colledge Engineering, see this **LINK**
                      GLR Distrubtors Ltd see this **LINK** also do Gauge plate.
                      Usual disclamers.
                      Regards Nick.
