Grinding wheel Spec.
Home › Forums › General Questions › Grinding wheel Spec.
  • #325348
    Clive Brown 1
      @clivebrown1
      I have a 6" bench grinder with 2 wheels, coarse and fine, which I use for off-hand sharpening of HSS lathe tools and drills. I'm thinking that the fine wheel is becoming due for replacement but I'm not sure of the best grit size. The present one is OK in that respect, I think that it's 60 grit, but the label is unreadable.
      Any advice appreciated.
      #25603
      Clive Brown 1
        @clivebrown1
        #325353
          60 grit grains 60 to the inch, so rather less than 0.5mm across, if that helps.
          #325354
          Thor 🇳🇴
            @thor
            Hi Clive,
            I use socalled white wheels on my bench grinder, 60 grit would be Ok but 100 grit would give a finer edge.
            Thor
            #325357
            mark smith 20
              @marksmith20
              Ive been using a fine one of these for years and think its great but on an 8" grinder. I think the grit was something like 100.
              Edited By mark smith 20 on 04/11/2017 10:50:14
              #325372
              Anonymous
                The grit size is determined by the number of holes per inch in a mesh. So allowing for the diameter of the wire mesh the grit size is slightly smaller than might be thought.
                While the finish obtained by grinding is, of course, related to grit size, it's not a particularly close relationship. The grit is randomly located on the wheel, so over a revolution or so any peaks tend to get ground down. A grit of 46, or 60, is often recommended as general purpose for a surtace grinder. A coarser grit is less likely to clog and need repeated dressing.
                It's a myth that the tool surface is directly replicated in the workpiece. It has an effect but it's not a one to one relationship. Consider using a Coventry die chaser as a cutting tool, so a nice regular V pattern. If the feedrate is exactly matched to the thread pitch then we'll cut a nice thread. But suppose the feerate is 1.5 times the thread pitch. Subequent teeth will tend to knock off the peaks left behind. Similarly if the feedrate is less than the thread pitch then the peaks left behind will be smaller than might be expected. Given that the roughness of the tool after grinding is likely to be pretty random in terms of peaks and troughs the finish obtained should be better than one might expect. After grinding HSS lathe tools I use a cheap diamond hone for two reasons. One, to remove any tiny burrs left on the cutting edge by the grinding process. Second, to remove a thou or two from a flank if I need a tool of a specific width ot shape.
                When I started dabbling in model engineering in the early 70s I bought all the standard ME text books mostly from MAP. In those honing of tools usually gets a mention in passing, but no more.
                I'm off to fit more spokes to my traction engine wheels, so fire away, I won't be offended. smile
                MAP = Model and Allied Publications
                #325417
                John Reese
                  @johnreese12848
                  I have tried several kinds of wheels and have settled on the friable white aluminum oxide wheels for tool sharpening. In the US they are most commonly found at purveyors of wood working tools.
