Governor drive belt
Governor drive belt
Home › Forums › General Questions › Governor drive belt
  • #602084
    Garry Coles
      @garrycoles69390
      Hi. Regarding the Stuart Turner governor spring belt. Once you screw the ends together, how do you get them apart again. It seems that when you screw them together the spring opens up slightly, but it seems impossible to unsrew because the spring tightens up. And is there other types of belt that will work as well on this sort of Governor.
      Thanks
      Garry
      #28742
      Garry Coles
        @garrycoles69390
        #602087
        Hopper
          @hopper
          Common rubber/neoprene O rings have been used in similar applications. Order by the inside diameter and cross sectional thickness.
          #602089
          Clive Brown 1
            @clivebrown1
            On my recently completed ST Williamson I used nitrile o-ring cord from e-bay, about 2mm dia. cut to length and joined with superglue. The joint seems reasonably durable though it's only a dummy govenor and I don't run for extended periods.
            Cutting the cord should be done with a scalpel blade or similar to give good square ends.
            #602117
            Garry Coles
              @garrycoles69390
              Thanks for the "O" ring idea. I will try that and see what happens.
              #602143
              Jim Nic
                @jimnic
                Another option is tape/video recoder drive belts which are flat rubber and thus a little more realistic. Packs of varying sizes are available from that renowned on-line auction site.
                Jim
                #602213
                bricky
                  @bricky
                  O my traction engine a 2" Burrell tractor I used a piece of leather fom a handbag strap.The straps are folded over and sown up. unfolded they are thin and are near scale for this application.
                  Frank
                  #602220
                  bernard towers
                    @bernardtowers37738
                    to undo spring belts just put under a bit of tension and unscrew, never had any trouble with mine. you might have been a bit over zealous with your tightening.
                    Edited By bernard towers on 18/06/2022 11:48:23
                    #602284
                    Howard Lewis
                      @howardlewis46836
                      Presumably, you want to shorten the spring belt?
                      If you cut the spring, as close to the tapered end, inside then spring, it ought to be possible to unwind the short end from the tapered end.
                      Then you can recheck belt length, cut to length and rejoin.
                      HTH
                      #602395
                      Garry Coles
                        @garrycoles69390
                        Thanks for the ideas. I have ordered some "O" ring and will try this first and if that is no good I will try some of the other ideas.
                        Garry
