Governor drive belt
Governor drive belt
Home › Forums › General Questions › Governor drive belt
  • #561033
    Garry Coles
      @garrycoles69390
      Hi, Has anybody got some ideas on how to join a governor drive belt. Mine is made of leather and is only 6 mm wide. I will have to join mine in place as it goes around the crankshaft as normal. I have tried to stitch mine but that is very tricky and not very good.
      Garry
      #28335
      Garry Coles
        @garrycoles69390
        #561126
        mark costello 1
          @markcostello1
          Skived and endless would work.
          Skiving a Bando type belt would work also.
          #561173
          Dave Halford
            @davehalford22513
            here maybe
            Jasons link to LSM lists a 1/2" belt, the joiner might work. Might be worth a call at least.
            #561214
            Roderick Jenkins
              @roderickjenkins93242
              The drive belt for the fan on my Farm Boy is made from 1.8 mm O ring material joined with a simple butt join glued with a generic cyanoacrelate (super glue). I've been very pleasantly surprised how robust the belt is, so a simple glued butt join may well be worth a try.
              HTH,
              Rod
              #561229
              steamdave
                @steamdave
                Posted by Roderick Jenkins on 04/09/2021 14:21:06:
                HTH,
                Rod
                It is interesting to learn that 'super glue' is flexible and lasting enough for a drive belt. If asked, I would have thought that Evostik type glue would have been the choice for this type of job.
                The Emerald Isle
                #561233
                  You can also get flexible "superglues" such as Loctite's "black max" that has some rubber in it and may be better for a scarf type joint in the flat belt
                  #561243
                  Garry Coles
                    @garrycoles69390
                    OK, thanks, will try some of the glues mentioned. I was just a bit concerned that the glues would be a bit stiff to go around the governor pulley because it's only 1/2 in diameter.
                    Garry
                    #561272
                    Roderick Jenkins
                      Posted by Garry Coles on 04/09/2021 17:24:18:
                      Garry
                      Which is why I went for the butt join rather than a scarf (as well as being easier cool) though I guess that leather might tend to wick a thin glue which would tend to stiffen up the joint area. A gel type glue might be better.
                      Rod
                      #561320
                      roy entwistle
                        @royentwistle24699
                        Rod It's a leather belt 6mm wide so presumably flat. Difficult to butt join
                        Roy
