Paul Lousick | 13/08/2021 08:49:59 |
2019 forum posts 712 photos | I am making a governor for my traction engine which uses a 20mm [or 3/4"] wide x 2mm thick flat belt from a pulley on the crankshaft. I need to find a supplier of small quantities of belt lacing clips to join the ends of the belt. Cannot use a continuous belt as it has to be removable. Lots for sale on ebay for larger sizes and in USA but in large quantities and exorbitant postage. Anyone recommend a supplier ? Paul Edited By Paul Lousick on 13/08/2021 08:53:13 |
roy entwistle | 13/08/2021 08:52:23 |
1504 forum posts | Would heavy duty staples do ? Roy |
Paul Lousick | 13/08/2021 09:02:37 |
2019 forum posts 712 photos | Similar to staples but it is a power transmission belt and is stronger and joined together |
JasonB | 13/08/2021 09:10:44 |
![]() Moderator 22605 forum posts 2643 photos 1 articles | LSM the model traction engine people do it by the 50mm length along with governor and flywheel belting. Page 44 of cat |
Paul Lousick | 13/08/2021 09:54:33 |
2019 forum posts 712 photos | Thanks Jason, My engine drawings, castings, etc. are from LSM. Paul |
old mart | 13/08/2021 15:06:23 |
3728 forum posts 233 photos | The Smart & Brown model A uses a 25mm x 3mm thick belt with a join in it sucessfully, I believe the belt and joining parts came from Lathes UK. I'm not sure if a 2mm thick belt can be joined mechanically, though. |
Martin Connelly | 13/08/2021 16:15:40 |
![]() 2125 forum posts 222 photos | It is usually called alligator fastener or alligator lacing if you want to search for it. I think the manufacturer is Balata or that may be a trade name. Martin C |
Pete Rimmer | 14/08/2021 18:06:54 |
1219 forum posts 63 photos | Clipper lacing is another. I have a Clipper lacer which is intended for use in vice jaws. Don't have any clips though. |
bernard towers | 14/08/2021 21:38:10 |
578 forum posts 109 photos | Lathes .co .uk have a belt supplier. |
John Reese | 16/08/2021 20:59:27 |
![]() 1035 forum posts | +1 on clipper lacing. It is probably the most compact of all the metallic lacing products. It does require a tool for installation The simplest tool is used with a bench vise. |
