Hi all, I am building the GLR vertical boiler, my first attempt at a boiler.
My query is regarding the bushes. It makes sense that tapping into the boiler shell alone is no longer acceptable but the instructions do not explicitly state the actual method, so do I-:
(a) Tap shell, screw in bushes and then silver solder.
(b) Profile end of bush to shell curvature and surface mount and solder.
(c) Fit plain bush into hole and solder.
The tap shell /screw bush in/solder way seems to be a good method to me but may not be acceptable for some reason not apparent.
Bill D.
