Gear specs
Gear specs
Home Forums General Questions Gear specs
Viewing 15 posts - 1 through 15 (of 15 total)
  • #334590
    Graham Williams 5
      @grahamwilliams5
      Have been asked if I can make a new magneto drive gear for a Velocette motorbike, it's a M series alloy motor, to replace a fibre type gear in the timing gearchain. Does anyone know the gear specs, PA, DP and the teeth are angled I believe.
      #25728
      Graham Williams 5
        @grahamwilliams5
        Velocette timing gears
        #334601
        Emgee
          @emgee
          Hi Graham, if gear information is not forthcoming you can always measure another gear in the train to help calculate the DP as a starting point, if the original mag drive gear is available but striped of teeth you should still be able to count the number of teeth..
          Emgee
          #334609
          John MC
            @johnmc39344
            92T 32DP, 20deg. PA, 16deg. LH helix. Top dia. 3.063", Ptich dia 3.00", Root dia 2.922", all+0 -0002".
            Hope this helps.
            Edited By John MC on 31/12/2017 12:36:33
            #334610
            Hopper
              @hopper
              Once again, the breadth and depth of knowledge on this forum leaves me gobsmacked. Well done and Happy New Year. beer
              #334623
              larry Phelan
                @larryphelan54019
                Hopper,I second that !!
                #334647
                Graham Williams 5
                  @grahamwilliams5
                  Thank you John MC, number 2 cutter available at RDG as I don't have 32DP, he'll have to cough for the cost of that if he says OK. You must be a Velocette motorbike engineer to have that knowledge to hand?????. I'm with Hopper and Larry Phelan but it's an old saying if you don't ask you don't (in this case find out).Happy New Year everyone.
                  Cheers
                  Graham
                  #334656
                  John MC
                    @johnmc39344
                    Graham, rather than making a gear why not buy a manual AR gear and modify that to carry the AT device? Not easy but you will be using a gear with properly generated teeth rather than the less than adequate formed teeth.
                    Graham Williams 5
                      @grahamwilliams5
                      John. Yes that would be a better approach, Just did ebay search but nothing there then went onto Velocespares site, 2 listed there, a lightened one? + another which is listing 11 degree angle, are there 2 different angles used on the gear (depending on model/year?) then?
                      Graham.
                      #334666
                      duncan webster 1
                        @duncanwebster1
                        Can someone explain? 92 t at 32 dp should be 2.875" pcd. If I divide by the cosine of the helix angle I still get 2.991" not 3" as JohnMC post. (I'm sure he's right by the way)
                        #334672
                        Baz
                          @baz89810
                          I am most probably wrong but I thought that RDG gear cutters are 14.5 PA
                          #334674
                          not done it yet
                            @notdoneityet
                            Duncan,
                            Maybe you are not adding 2 to the tooth count before dividing by 32?
                            Or maybe these gear calls are too complicated for me!
                            Edited By not done it yet on 31/12/2017 20:30:04
                            #334675
                            Graham Williams 5
                              @grahamwilliams5
                              Baz, missed that, 14 1/2 degrees is what RDG have, but CR Tools in Sheffield list both 14 1/2 and 20 degree PA, probably very expensive. Given the suggestion by John to modify a 'manual' magneto drive gear, that appeals the most, will have to ask if the angle on the one on the motorbike can be checked so as to completely eliminate the 11 degree mentioned on the other web site.
                              Cheers
                              Graham.
                              #334730
                              John MC
                                @johnmc39344
                                Posted by Graham Williams 5 on 31/12/2017 18:41:52:
                                Graham.
                                I believe that Veloce used spur gears in the early M series, then 11deg helix before finally settling on the 16deg helix angle The gear dimensions I have given will fit the Venom and Viper models, You could try Grove Classic Motorcycles for a gear.
                                #334755
                                duncan webster 1
                                  @duncanwebster1
                                  Posted by not done it yet on 31/12/2017 20:26:45:
                                  Duncan,
                                  you don't add 2 to get the pcd, that's to get the OD
