Gaskets and sealants in the smokebox area???
Home › Forums › Beginners questions › Gaskets and sealants in the smokebox area???
  • #515692
    Mike Paling
      @mikepaling69128
      Hi folks …
      I am slowly making progress with all of the fittings and pipes in the smoke-box area of my 3 1/2"g large boilered Tich. I am using coned fittings where appropriate but I can see that I will need some gaskets and/or thread sealant in other places in places.
      I would like to think that I can take things apart in the future if needed so I am unsure if thread sealant can be taken apart without problems … so …. are gaskets a better option???
      I know that it will get pretty hot in the smoke-box area due to the hot flue gasses …. but which gaskets will cope with this sort of heat … if any???
      Any suggestions gratefully received
      #10595
      Mike Paling
        @mikepaling69128
        #515704
        Grindstone Cowboy
          @grindstonecowboy
          I've become a convert to this stuff – as far as I know it should be up to the job.
          (Other suppliers are available)
          Rob
          #515722
          Tony Wright 1
            @tonywright1
            Just use silicone sealer,it’s heat resistant and easy to separate if required. Been using it for years no problems
            Tony Wright.
            #515746
            Jon Lawes
              @jonlawes51698
              I like Loctite 567. It seals well but is also easily disassembled. Rated to around 200 degrees C but I think it comfortably copes with more.
              Edited By Jon Lawes on 27/12/2020 19:34:23
