Freesat recorder HDD
Home › Forums › The Tea Room › Freesat recorder HDD
Viewing 25 posts - 1 through 25 (of 25 total)
  • #647522
    Malc
      @malc
      Has any one replaced a HDD in a Freesat box? It’s a Manhattan 4K 500GB recorder, it’s only 18 months old but the HDD has failed and Manhattan tell me that I will just have to buy a new box. A replacement HDD is less than £15 so I am tempted to buy one. I can hear the old HDD operating so I know it is getting power. Does anyone know whether you can just replace the HDD or will it need formatting or pre programming in some way?
      #37235
      Malc
        @malc
        #647528
        John Doe 2
          @johndoe2
          Don't know but before you do, take the mains plug out of the wall socket, then open the Freesat box and very carefully and one by one; remove and replace all the mutli-connectors you can see, starting with the one from the HDD block to the main board. Bear in mind some have locking tabs.
          If you are not familiar with electronics, don't touch any metal or components – there is a small possibility of power supply capacitors giving you a shock – only touch plastic multi-connectors.
          Then replace the housing and try the box again. 80% of "electronic" faults are due to interconnections going bad, so you might be lucky.
          #647533
          Oldiron
            @oldiron
            I have changed hard drives in a lot of DVR's from cheapys to very expensive units. It is not a difficult job usually a few screws and 2 cables on the HD. Just the same as doing it on a PC. Every unit I have changed has gone through it startup procedure and formatted the HD to suit its own system. You can on most DVR's put in a larger HD than was originally fitted. Observe all the usual rules when dealing with electrical and electronic items.
            regards
            #647536
            modeng2000
              @modeng2000
              Really useful information Oldiron, thanks for when I might need it.
              Malc
                @malc
                Thanks Oldiron, that’s encouraging. I decided to risk it and have sent for a new hard drive. Hope be up a running again soon. Thanks again.
                #647594
                Anonymous
                  There's quite a lot of information on doing this (including YouTube tutorials) if you Google:
                  freesat hard drive swap
                  Edited By Peter Greene 🇨🇦 on 05/06/2023 21:14:03
                  #647597
                  Malc
                    @malc
                    Thanks Peter, I’ll check them out.
                    #647604
                    Sakura
                      @sakura
                      Don't touch it! Quote the Sale of Goods and Consumer Protection Act to them. It states that goods should be of merchantable quality and it is generally accepted that that means a lifespan of 6 years. Threaten them with taking them to the Small Claims Court and or reporting them to your local Trading Standards. 18 months is totally unacceptable.
                      #647608
                      Bazyle
                        @bazyle
                        The HDD in a recorder is under way more stress than a PC so the disc manufacturers make special versions for them, so your replacement might not last as long as you expect. Some Freesat boxes may be less regulated than Sky or VM which are required by the film makers to pair the disc to the box during production so that you cannot switch and pass the disc plus recordings to a mate to watch films they haven't paid for,
                        #647618
                        Steviegtr
                          @steviegtr
                          I had a few problems in the past with these recorders. I kept thinking the hard drive had failed. But it was usualy because the drive was nearing its full capacity & would simply fail. I used to remove the drive & fit to a P.C. Then delete the recordings & then refit to the recorder. They would then run fine. I soon came to the conclusion that they regularly needed the watched content deleting. Even now with our SKY Q box I delete regularly or they start to play up.
                          Steve.
                          #647652
                          Malc
                            @malc
                            I posted this question on a specialist AV website forum – I’m still waiting for a reply. I’ve found in the past that I can usually count on a response from you fellas. I’m always amazed at your breadth of knowledge and willingness to help. Thanks again to all.
                            #647655
                            John Doe 2
                              @johndoe2
                              Yeah, I would have tried reseating all the internal interconnections before buying a new HDD though. Nothing to lose.
                              A report of an HDD fault does not necessarily mean there is an actual HDD fault. It could be a problem with the data from the HDD not reaching the main board, or being corrupted, owing to a poor connection.
                              Having said that, I agree with Sakura and would have been back to the shop manager first.
                              #647678
                                Not sure I'd make much fuss over a £170 HDR that's out of warranty. It's borderline. A Small Court Claim costs time and money, plus the hassle factor. The court decides what a reasonable lifetime is, it depends on the item, and they might not agree with the plaintiff!
                                What's the actual error? Steve's suggestion the disc is full rather than broken is a possibility.
                                I'd try a factory reset and disc format. If that fails swapping the HDD is worth a punt.
                                Malc
                                  @malc
                                  This recorder had been playing up for a week or two, failing to record, incomplete recordings etc. I tried factory resets a couple of times to no avail. Finally it displayed a “Something is wrong” screen suggesting to re boot the HDD. However it repeatedly refused to reboot. I rang the Manhattan service and explained all this and they said that the HDD was at fault and my only option was buy a new recorder. I complained, saying that it was only 18 months old, they said that whilst they did have some leeway in their guarantee period I was not eligible after 18 months. Having nothing to lose I opened the box and checked and cleaned all the HDD connections – no luck. I could hear the HDD running so I felt that it was getting power OK. At this point I found the exact same HDD on Amazon for £13:40 and thought that it was worth a gamble at that price. It should arrive tomorrow so I’ll soon know whether my gamble paid off.
                                  #647721
                                  Justin Thyme
                                    @justinthyme24678
                                    Posted by Bazyle on 05/06/2023 23:19:19:
                                    In light of this thread I was just considering our PVR. Bought in 2009, it is now 14 years old. Due to a fault where it sometimes fails to record from standby, we have left in permanantly on. As it is a 'pause' live tv type then we can assume the disc is spinning at full speed 24 hours a day? (5400 rpm)
                                    so it may ave spun round 45 billion times – impressive bearing!
                                    and if its little 3.5" disc had been a wheel it would have made it around the world 315 times ! averaging just under 60 mph
                                    Edited By Justin Thyme on 06/06/2023 23:03:40
                                    Edited By Justin Thyme on 06/06/2023 23:04:13
                                    #647725
                                    david bennett 8
                                      @davidbennett8
                                      Posted by Justin Thyme on 06/06/2023 22:59:48:
                                      Justin,I have Humax pvr of similar age to yours. Like you I had to leave it running . Eventually (yesterday ) it gave up completely on recording or playing. In a try anything mood, I cured it with a re-set to the settings and a re-format of the hdd. You lose your recordings, but it's running like new now.
                                      dave8
                                      Edited By david bennett 8 on 07/06/2023 01:37:12
                                      #647726
                                      Anonymous
                                        Don't really know the hardware under discussion, but normal design would have the HD sleep when it isn't actually being used, even if the equipment is powered. Network drives for example typically do this.
                                        Even so, it could be advantageous to use a SSD if replacing the drive. The spinup time is essentially zero and the power consumption much less.
                                        #647727
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Hi, not sure it makes the HDD to be matched exactly. I have my main TV in my lounge, and a small one in my kitchen, both of which can record any of the TV programmes onto any USB memory device, however, if I record something on my main TV, it can't be watched on the TV in the kitchen, or vice versa, nor can it be view on a PC or through the USB ports on my Blu-ray player . So I imagine the recordings are encrypted to only be read by the device they are recorded on.
                                          Regards Nick.
                                          Edited By Nicholas Farr on 07/06/2023 07:20:38
                                          #647731
                                          Justin Thyme
                                            @justinthyme24678
                                            Posted by Peter Greene 🇨🇦 on 07/06/2023 01:45:45:
                                            It is a 'pause and rewind' one, so at any moment you can rewind up to one or two hours of whatever side you are on (providing you have not switched channels) So it never ever has a rest. so wasteful in so many ways, but also quite incredible it achieves this, 14 years of non stop spinning and recording.
                                            How are the bearings formed in these HDD ? and then there is that little arm that continuously moves back and forth across the surface of the hard disc with such incredible accuracy.
                                            #647750
                                            Circlip
                                              @circlip
                                              Reported on this a while ago, mine was a 500G Seagate in a 'Humax Freesat 1100S. Prices ranged from about £40 to £15, both for new units and again on this site (M E) was advised to go for a 'Blue badge' grade, these seem to be for CCTV recorders. Mine came as this without asking. It's a SATA drive, so only one connection.
                                              Easy job, but make sure you 'Discharge' yourself before doing it.
                                              Regards Ian.
                                              Edited By Circlip on 07/06/2023 10:54:37
                                              #647991
                                              Malc
                                                @malc
                                                Just to finish my tale fellas, I fitted the new HDD into my Manhattan Freesat recorder and it fired up OK and has been going great for a couple of days now. Seems to be doing all it should be doing. Keeping my fingers crossed!
                                                #647999
                                                modeng2000
                                                  @modeng2000
                                                  Brilliant angel
                                                  #648537
                                                  Speedy Builder5
                                                    @speedybuilder5
                                                    Hi Malc, I replaced my drive in a HUMAX recorder a year ago. The drive I fitted was 2x the size of the original as that was what was available to me. Installed the drive, formatted it – all OK. The software reported the new size. The other day it stopped recording with the message "Insufficient space on the drive" reporting the original drive size.
                                                    The software is set to auto delete old recordings to make space for new recordings. It seems that one part of the software reports actual available space and another sets a fixed limit of the original drive.
                                                    I have now re-formatted the drive and it is recording again OK.
                                                    Bob
                                                    #648546
                                                    Oldiron
                                                      @oldiron
                                                      Posted by Malc on 09/06/2023 18:50:17:
                                                      Good result Malc.
                                                      regards
