Freeing a cabinet lock
Home › Forums › Help and Assistance! (Offered or Wanted) › Freeing a cabinet lock
  • #33719
    Greensands
      @greensands
      #506506
      Greensands
        @greensands
        Hi – I wonder if anyone can suggest a way of solving the problem I have with a small lock fitted to a china display cabinet. The key shown is obviously is not the correct one for the cabinet but somehow or other it was used to operate the lock in one direction, (fortunately with the door open) but I cannot now get it to work in the reverse direction. All suggestion most welcomed.
        #506511
        Brian Wood
          @brianwood45127
          Remove the lock from the cabinet, take off the back from it and then you will be able to see which wards on the key are doing something useful.
          It is a simple key to make a new version. A blank to that pattern would be readily available at the local locksmith and you can file your own wards on that to operate the lock correctly
          Regards Brian
          #506514
          Rod Renshaw
            @rodrenshaw28584
            The key does not fit this lock and unless it is needed for some other lock you could hacksaw it into 2 parts which will enable you to remove the lock from the cabinet door. Then either follow Brian's suggestion or take the lock to a locksmith and order a new key.
            Rod
            Apologies, I thought the key was stuck in the lock!
            Edited By Rod Renshaw on 10/11/2020 18:08:52
