Four facet drill grinding.
Home Forums General Questions Four facet drill grinding.
Viewing 25 posts - 1 through 25 (of 26 total)
  • #541694
    alan ord 2
      @alanord2
      Help!! I am trying to find an article on 4 facet drill sharpening published in either ME, MEW or EIM. I'm sure I read an article in the last few years. I have tried searching the on line index of published articles, using various combinations for the search without success. There are older articles pre 2008 but I'm sure there was a more recent article. Does anybody know what the mag and issue or date was. I'm pretty sure I'm not suffering from the onset of dementia. At least I hope not!!!!!
      Alan.
      alan ord 2
        @alanord2
        #541699
        Alain Foote
          @alainfoote90915
          DAG Brown Model Engineer 1994 no. 3968 is a good starting point.
          #541700
          bernard towers
            @bernardtowers37738
            DAG Brown has done articles in the past but there is one in ME Jan/Feb 1995 by Roland Gyllander from Sweden. i have made his jig but found it susceptible to variable hand pressure so have adapted it to fit directly on the T and C table removing the variable hand pressure problem. I have made a start on a article for MEW about the adaption but not finished yet! and sometimes think people have had enough of four facet articles. if interested drop me a PM
            #541704
            alan ord 2
              @alanord2
              Thanks Alain, I did see that ref in the online index and I do have the mag. But I'm sure there was a more recent article published in the last few years. If all else fails I will have to do it the hard way and do a manual search.
              Alan.
              #541705
              Martin Kyte
                @martinkyte99762
                Here is some info for starters.
                regards Martin
                #541706
                Journeyman
                  @journeyman
                  There is an article by Gadget Builder in HSM (Home Shop Machinist) try this link to his pages there is a whole load of info on drill grinding , jigs and some of the theory. Also a powered 4-facet grinder/jig ** Drill Sharpening **
                  alan ord 2
                    @alanord2
                    I've found it.
                    ME Vol 215 issue 4513 2015 by D.A.G. Brown. The reason I could not find it using the on line index was because the title of the article is "Further Developments in Drill Sharpening"
                    Dementia not just yet!!!!
                    Thanks to all for your advice.
                    Alan.
                    #541717
                      Well-found, Alan
                      A collection of data becomes information when you properly index it.
                      Howard Lewis
                        @howardlewis46836
                        D A G is very expert at four facet drill grinding on his Quorn.
                        Four facet ground drills cut extremely well and a centre drill for starting is not obligatory.
                        Keeping the lip lengths equal is the secret to having accurately sized holes.
                        You are effectively grinding a two flute End Mill or Slot Drill with` inclined faces.
                        #541739
                        alan ord 2
                          @alanord2
                          Thanks MichaelG but I was somewhat fortuitous. I took a punt and started searching ME first from the last issue. Checking each vol index until I got to the 2015 article. I wasn't going to go much further before abandoning ME and going onto MEW and EIM indexes. So think I was lucky.
                          Alan.
                          #541753
                          Robert Dodds
                            @robertdodds43397
                            Is the reprint article of Giles Parkes of any interest
                            From the Archives: Twist drill Sharpening by the Four Facet Method
                            Model Engineers' Workshop|May 2020 No293
                            The original article was published in 2000 MEW 64.
                            Bob D
                            #541759
                            Martin Kyte
                              @martinkyte99762
                              Posted by Howard Lewis on 26/04/2021 18:58:59:
                              He claims, and there is no reason to doubt him, that his drills do not snatch in brass either.
                              regards Martin
                              #541779
                              Emgee
                                @emgee
                                The method is detailed in the Quorn construction book.
                                Well worth the effort but I tend only to use the method on 1/4" up sizes.
                                Emgee
                                #541782
                                Vic
                                  @vic
                                  Posted by Journeyman on 26/04/2021 17:18:45:
                                  Thanks for that John. I came across this quite some ago but is one of several good links I’ve “lost” over the years. It remains a very comprehensive article on drill sharpening.
                                  #541879
                                  Howard Lewis
                                    @howardlewis46836
                                    Not sure who started four facet grinding of drills, but the late Giles Parkes advocated, and used it, on his Worden Cutter grinder. Relative easy to do, and well worth the effort..
                                    #541892
                                    Douglas Johnston
                                      @douglasjohnston98463
                                      That is an interesting 4 facet grinder. Does anybody happen to have a copy of the article from HSM as I would love to have a look at it.
                                      Doug
                                      #541897
                                      Journeyman
                                        @journeyman
                                        Posted by Douglas Johnston on 27/04/2021 16:06:24:
                                        Doug
                                        I got a copy from John Moran (AKA Gadget Builder) try his Email: John at GadgetBuilder.com if you get no joy PM me and I will rummage in the archive and see if I can find it. He sent it to me as a web page.
                                        P.S. Don't forget to change the ' at ' for a @
                                        Edited By Journeyman on 27/04/2021 16:39:10
                                        #541898
                                        Brian Baker 2
                                          @brianbaker2
                                          I have made Bernard Towers modified 4 facet drill grinding jig, from a pre published set of drawings and it works well. It is designed to fit onto the Stent, and makes the job straight forward and quick.
                                          I think it should be published Bernard, and it is a useful addition to the Stent.
                                          However, I have purchased a Quorn, which I like, and the Stent, including Bernard's jigs have been sold.
                                          Publish it Bernard!
                                          Brian B
                                          #541937
                                          alan ord 2
                                            @alanord2
                                            Bob D thanks for the info. I will dig out the articles.
                                            Alan
                                            #541966
                                            Douglas Johnston
                                              Posted by Journeyman on 27/04/2021 16:38:08:
                                              Doug
                                              Thanks for providing that email address John. I contacted John Moran and he has sent me the relevant files. This will keep me in reading matter for a while, then I will decide whether to make one.
                                              Doug
                                              #541974
                                              bernard towers
                                                @bernardtowers37738
                                                Thanks Brian, Article has been half written fo ages perhaps I should finish it!
                                                #542017
                                                Howard Lewis
                                                  @howardlewis46836
                                                  The advice with an old kit for the Worden advised making a collet for each size of drill.
                                                  I followed, without realising, Giles Parke's method, of making an ER20 collet holder in a piece of 1" square steel, (The size used in the fixtures for the Worden. )
                                                  his allows drills of up to 13 mm to be held.
                                                  The drill is clamped in the ER20 collet, so that one cutting edge is vertical.
                                                  My holder is marked to identify the faces, so that rotating the holder through 180 degrees is obvious, if a an already ground face has to be revisited.
                                                  The Table is set square to the grinding wheel.
                                                  Fitted into one of the "standard" drill grinding fixtures (Inclining the drill at 31 degrees ) the complete assembly is swung through 30 degrees to produce the secondary clearance.
                                                  Once this is done, the fixture is reset to 10 degrees to produce the primary clearance.
                                                  The end result should be the primary reliefs being of equal width where they meet at the chisel edge in the centre.
                                                  #612809
                                                  Alan Wood 4
                                                    @alanwood4
                                                    I've just completed a joint cooperation with John Moran to produce a hybrid 3D print / metal version of his four facet sharpener. The hybrid construction concept works very well making the whole thing much easier to produce.
                                                    You can download a ZIP file with Fusion files, STEP files and PDF drawings from my blog.
                                                    #612814
                                                      Posted by Howard Lewis on 28/04/2021 10:40:09:
                                                      Coincidentally, Howard's detailed article on this subject will be in MEW 320!
                                                      I passed the proof half an hour ago!
