Fortis lathes
Fortis lathes
Home Forums 3D Printers and 3D Printing Fortis lathes
  • #441095
    vic donnelly
      @vicdonnelly54749
      Hi Marischal, I see in the photo of the Fortis parts that you have the change gear cover. As mine is missing I have to fabricate (mig weld) one. If I send you the postage could you take a template of end so that i can cut one from 16g steel. With the help from yourself and many others I have sorted my gear problem. thanks again. Vic Donnelly.
      #31617
      vic donnelly
        @vicdonnelly54749
        Change gear guard
        #441099
          Posted by vic donnelly on 10/12/2019 19:37:11:
          Hi Vic – to contact a forum member direct, click 'message member' under any post.
          Delete the member name that comes up (unless it's the person you want to contact).
          Start typing the member name that you do want to contact and you will get a list to choose from (it gets more specific as you add letters).
          Hope that helps,
          vic donnelly
            @vicdonnelly54749
            Thanks for that, I will give it a try. Vic.
