Fixed Steady for Square Stock
Home Forums Beginners questions Fixed Steady for Square Stock
  • #466204
    woody1
      @woody1
      Evening,
      How would you go about boring a 19mm diameter hole in a 100-115mm length 30mm square ally on a 7×12? I can only think to mount the stock, put a long drill in the 3 jaw which would be a pain, rough finish and inaccurate. The best option would be the 4 jaw and a steady. However the only way I can think to make a steady for Square is use a large bearing (which I have) cast up a housing plus an inside race with fixings either side to clamp. Am I over over thinking this? I have limited experience with square and have had some failures doing similar. Bloody shape has to many sides!
      Thanks.
      #10176
      woody1
        @woody1
        #466206
        Hopper
          @hopper
          You need a cat's cradle. Basically a round sleeve that fits over your square bar where the steady sits. Eight bolts with locknuts – four around the diameter at each end– hold the sleeve in position.
          #466207
          not done it yet
            @notdoneityet
            Don’t know, but… maybe start with a piece longer than finished size and turn, with tailstock support, a section for the fixed steady to bear on. Then sort out the hole. May need finger collets in the tailstock and settle for a reamed hole if not enough room, but removing the tailstock might provide enough space for boring?
            Alternatively get someone else to do it🙂 or buy a bigger lathe.
            #466208
            woody1
              @woody1
              Posted by Hopper on 21/04/2020 23:06:09:
              Awesome I new I was over thinking itcrook.
              So just use a piece of DOM tube of suitable size drill and tap either side of steady clock in and crack on.
              I just spend an hour looking for a "square stock steady"! Cats cradle has thrown up loads! Thanks a million fella!
              #466210
              Hopper
                @hopper
                Have fun!
                #466211
                woody1
                  @woody1
                  Its been a long day grinding valves, I think the compound has got in my veins! I have been think about it all day and how to solve but the bearing in a housing just kept seeming to be the logic. It would work in the same way as a cats cradle but would take a tonne of work, time and a lot swearing to produce.
                  Again thanks, I can relax now.
                  Edited By woody1 on 21/04/2020 23:23:04
                  #466213
                  Nigel Graham 2
                    @nigelgraham2
                    One suggestion:
                    Clean up a section of the bar near the tail end.
                    Turn a simple cylindrical bush, generously thick-walled, to be a tight push-fit on that area.
                    You might want to fit a grub-screw that will sink below the outer surface and touch one of the flats (use a shim pad to protect the surface), as the bush contacts the work-piece only on the edges.
                    Now support the work in the 4-jaw with the steady running on the bush – but ensure accurate centring in the chuck otherwise the outer end of the bar will try to move in a circle exaggerating the error, and cause a lot of problems.
                    Another, based on a long-established trick for good-quality square bar, is to make two such bushes, both a tight push-fit. The first as above, the other split along its length to be gripped wrapped round the stock, in a 3-jaw chuck.
                    Probably the ideal way for a task like that is to use a between-centres boring-bar if you have those and a T-slotted saddle on your lathe. You would still use a long drill for the pilot hole.
                    #466216
                    woody1
                      @woody1
                      Posted by Nigel Graham 2 on 21/04/2020 23:21:58:
                      One suggestion:
                      Thank you,
                      Another way to skin a cat! I have made and use a tonne of machined and split DOM tubing to hold work I don't want to mar. This is serious knowledge! So simple when you think about it but hey I'm not ace (yet).
                      Also how does between centre boring work?
                      Thanks a million.
                      #466217
                      woody1
                        @woody1
                        One suggestion:
                        I understand mount the work on the T-slotted, boring bar between centres and use the feed. The 7×12's however don't have slots! A major faux paux in my opinion! I dont think a T-slotted is possible for me. Im thinking to buy a spare cross to use and brutalise as a clamping table. There only £30.
                        #466227
                        Paul Lousick
                          @paullousick59116
                          A cat head is sim[le to make. Previous post with an example shown here but instead oh holding in the chuck use a fixed steady. The double row of bolts alows you to centralize it on your job and align it with the axis
                          Paul
                          Edited By Paul Lousick on 22/04/2020 03:59:01
                          #466248
                          Ady1
                            @ady1
                            I grabbed a couple of big propshaft bearings and gearbox bearings from a taxi garage years ago
                            You put the bearing around the workpiece and mount it in the fixed steady
                            Also handy for supporting very long jobs which need work done at the chuck end
                            GL
                            edit: that tubing idea is a great quick fix
                            Edited By Ady1 on 22/04/2020 08:46:55
                            #466251
                            Clive Brown 1
                              @clivebrown1
                              What size is the 4-jaw?
                              My 6" 4-jaw is fairly typical for a model-makers lathe. I'd be happy with drilling and boring aluminium alloy as per OP with around 80mm overhang from the chuck jaws without a steady.
                              Edited By Clive Brown 1 on 22/04/2020 09:09:53
                              #466255
                              Hopper
                                @hopper
                                Lol just reread the OP. Yes its only 100mm long so just hold it in the 4 jaw and drill it.
                                #466267
                                Martin Kyte
                                  @martinkyte99762
                                  Alternative on a Myford would be mount on the boring table and use a between centres boring bar after drilling.
                                  But as has been said stick it in the 4 Jaw and go without the steady.
                                  regards Martin
                                  #466286
                                  HOWARDT
                                    @howardt
                                    I have just bored a 20mm hole in a similar size block of cast iron on my 7×16. Four jaw chuck and light cuts after a 12mm drill, changed boring bar to bigger size as soon as would go in, no steady,
