File card sourcing?
File card sourcing?
Home › Forums › General Questions › File card sourcing?
  • #25298
    Andrew Tinsley
      @andrewtinsley63637
      #302216
      Andrew Tinsley
        @andrewtinsley63637
        Not sure if I have the name correct, but I am looking for a source of file cleaning material.
        I have just used the last of my 25 year old cache and need some more!
        Andrew.
        #302217
        Jon Gibbs
          @jongibbs59756
          Is this what you're looking for? **LINK**
          Jon
          #302218
          Martin Kyte
            @martinkyte99762
            Personally I find Brass better at cleaning files.
            It works like this. Fix a 3 or 4 inch piece of square or rectangular brass into a file handle. File the end to a chisel shape. Put the file to be cleaned in the vice flat uppermost. Using the brass tool at a shallowish angle gouge out all the dross working side to side diagonally along the file parallel to the file teeth. The chisel point very quickly conforms to the pitch and shape of the file teeth and will get right down to the bottom of the serrations. Resharpen every so often as needed.
            regards Martin
            #302219
            Andrew Tinsley
              @andrewtinsley63637
              Thanks Jon and Martin,
              Looks like just what is required, I shall try both cleaning methods and see what works best for me.
              Andrew.
              #302220
              steamdave
                @steamdave
                A handy length of flattened scrap central heating copper pipe works just as well as the brass bar and for the impecunious amongst us, could work out a cheaper option.
                The Emerald Isle
                #302278
                mechman48
                  @mechman48
                  Posted by steamdave on 12/06/2017 15:28:17:
                  The Emerald Isle
                  ​+1, that's what I use
                  Geo.
                  #302323
                  Ian S C
                    @iansc
                    If you want a "file card", find a place that cards wool, or other fibre, thats what they use. My file card came from my Scotish grandfather Who lived in Paisely, so I presume it cme from one of the mills there.
                    Ian S C
                    #302356
                    KWIL
                      @kwil
                      Copper tube cleaners are more kind to the sharp edges of the files, "file card" tends to dull the edges.
                      #302387
                      Ian S C
                        @iansc
                        Kwil, I agree, I tend to use either a bmall brass brush, or I have a bit of copper tube attached to a file handle for the heavy cleaning.
                        Ian S C
