Empty drill box
Empty drill box
Home › Forums › General Questions › Empty drill box
Viewing 21 posts - 1 through 21 (of 21 total)
  • #305837
    Eric Cox
      @ericcox50497
      Does any know where I can get an empty graduated drill box from to house my numerous individually obtained drills.
      #25345
      Eric Cox
        @ericcox50497
        #305840
        Martin Kyte
          @martinkyte99762
          I didn't but I do now.
          Google, him say eBay.
          regards Martin
          #305847
          Brian Wood
            @brianwood45127
            Eric,
            I have one looking for a home—send me a PM please with your address.
            #305850
              Might help if you said if you need metric, imperial, number, letter, etc and also range of sizes and increments.
              #305851
              Bazyle
                @bazyle
                Often left over on bitsa sales stands because everyone wants the other size……..
                #305863
                Brian Wood
                  @brianwood45127
                  Eric,
                  ​I am rather embarrassed to say I can no longer find it, I had a bench clearance some time ago, put things in a box which I have since misplaced!
                  ​So, it might be better for you to see if someone else can help you instead. I'm sorry to have got your hopes up.
                  #305868
                  Eric Cox
                    @ericcox50497
                    That's OK Brian, thanks for the offer.
                    I'm looking for Imperial, 16th's or 32nd increments 1/8" to 1/2"
                    #305870
                    Martin Kyte
                      @martinkyte99762
                      something like this.
                      David Standing 1
                        @davidstanding1
                        By Eric saying 'empty graduated drill box', i'm guessing he means something like this:
                        But, I don't like guessing, so I guess he will clarify wink 2.
                        #305879
                        Martin Kyte
                          @martinkyte99762
                          he also said he wanted somewhere to put his drills. So perhaps a stand would suit him better. Who knows?
                          regards Martin
                          #305880
                            several on MSC similar to this
                            #305905
                            Steven Vine
                              @stevenvine79904
                              I like the look of these …HQ Rocky
                              David Standing 1
                                @davidstanding1
                                Posted by Steven Vine on 06/07/2017 17:40:29:
                                Except you would have to cut all your drills in half to be able to get the lid on smile o
                                #305913
                                Steven Vine
                                  @stevenvine79904
                                  Posted by David Standing 1 on 06/07/2017 18:00:02:
                                  I don't think there is a lid, just a handy storage tray that goes under.
                                  #305914
                                  peak4
                                    @peak4
                                    Unless you can find someone, like Brian, with a spare one, it's probably going to cost you a tenner by the time you've paid the postage.
                                    This one on ebay with slots from 1/16- 1/2 in 1/64ths is only £13.80 delivered; the trouble is, that it's already full of drills, so it still leaves you with the same issue. wink
                                    #305915
                                    Enough!
                                      @enough
                                      Try "Drill Index" when searching
                                      #305918
                                      David Standing 1
                                        @davidstanding1
                                        Posted by peak4 on 06/07/2017 18:08:55:
                                        The old problem of getting rid of a heap of soil – answer, dig a hole and bury it wink 2
                                        #305925
                                        larry Phelan
                                          @larryphelan54019
                                          WHY NOT JUST DRILL A BLOCK OF HARDWOOD WITH EACH DRILL AND MARK IT,S SIZE ?
                                          SEEMS SIMPLE ENOUGH TO ME !
                                          #305937
                                            Buy a cheap set from Screwfix or Toolstation and throw the drills in the DIY box with the left over nails and screws.
                                            #306212
                                            Howard Lewis
                                              @howardlewis46836
                                              If all else fails, why not make a stand? Take a piece of metal and drill a hole with each drill, gradually increasing in size, and job done! All it will cost is a bit of steel, (or sheet aluminium fixed to a block of wood) and a little time.
                                              Do Cromwell , Machine Mart, Toolstation or Screwfix offer empty drill boxes? (Sure that I've seen them advertised somewhere)
