Elliott Omnimill – can you help?
Home › Forums › Manual machine tools › Elliott Omnimill – can you help?
  • #486113
    Michael Cross 4
      @michaelcross4
      Hello,
      Can anyone advise on the best way to remove the knee from an Elliott Omnimill – should I leave the knee attached to the screw and lift if out all together or is it possible to detach the screw and lift the knee off (which would me my preferred option)? If so how do you detach the screw?
      Also – might anyone be able to help me out with a pdf manual?
      Thanks
      #13979
      Michael Cross 4
        @michaelcross4
        #486123
        Ian McVickers
          @ianmcvickers56553
          Remove the knee with the screw attached, just remove the 3 bolts holding it down to the base. You can then easliy remove the screw , if required, when its on the bench or floor.
          #486130
          Michael Cross 4
            @michaelcross4
            Thanks, I've just seen your rebuild; looks great. I might be back for more advice!
