Elliott M10 Shaper rebuild – new drive shaft needed
Home › Forums › Manual machine tools › Elliott M10 Shaper rebuild – new drive shaft needed
  • #209975
    mick vann
      @mickvann94362
      Hi Chaps, has anyone rebuilt a Elliott M10 shaper, i need to remove the clutch drive shaft and was looking for the best way to go about it as it is bent.
      Does anyone have a spare ?
      TIA Mick
      #12570
      mick vann
        @mickvann94362
        Drive shaft removal
        #210005
        Brian Wood
          @brianwood45127
          Hello Mick,
          If you need drawings to show you how it is fitted, I can help there, but not with a replacement shaft I'm afraid. Send me a PM if that would be helpful
          Shafts aren't difficult to straighten, for minor bending at least, using a wooden block and lump hammer with the shaft supported on two lumps of timber. with Vee notches cut into them.
          Progress can be readily checked by rolling the shaft round in two vee blocks and then knocking out the high spot accordingly
