Electronics is not "obvious" in the way that mechanics are. That makes it harder to learn. You have to be able to do some maths to be able to figure out what it happening. Somehow you have to trust that your understanding, with the maths applied, really is what is happening.
If you get that bit wrong, then you won't figure out why it doesn't work without trial and error, which is going to be slow. Trial and error can sometimes be the answer, but without the maths you don't know how big the error was. The consequence is that you have no idea what to try next.
I've heard it called "stabbing in the dark". It is why electronics is difficult.
Mechanical engineering is not the same. There are things you have to know, but if the widget isn't long enough to reach, then you have to make another which is longer. If it keeps breaking, then it has to be thicker or made of a stronger material.
Mechanics and electronics are different beasts. Mechanics can be the art of making things to someone else's design. Hobby mechanics can simply be development of the skill and knowledge required to make something that looks nice and works well, from raw materials.
Electronics is different. By comparison there isn't much art in making a radio to someone else's design. It is enough for some people, but you can make the radio and it looks terrible, but works just as well as an immaculately constructed one.
The "art of electronics" is understanding and optimising what is happening. If you don't want to understand it, then there isn't much art to it.
I wouldn't recommend reading "The Art" from cover to cover. It's not that sort of book. The whole point of it, is that you get an electronics cookbook. If you want you can buy your own cookbook with circuits that you like, or want to explore. When you have built your circuit and it doesn't work, or you just don't understand why it does work, then "The Art", will explain why.
It probably won't answer your question directly, but if you use your brain, it will help you to realise the answer for yourself.
To those that don't like the book, I suspect it's because you've not tried hard enough.
