Hi fizzy,
This is not anything in the form of a solution to the problem. It is just to see if my understanding is correct. Am I correct in assuming the pump needs to deliver water into the boiler at a pressure at least equal to the working pressure of the boiler and also the rate of flow does not need to be much more than the rate at which the heat source can turn the water into steam ? ie. A high pressure low volume pump is required.
PS the title amused me. It made me thing the boiler was heated electrically.
Les.
Edited By Les Jones 1 on 19/04/2015 14:30:13
