eclipse hss tool broken in 2
Home › Forums › Beginners questions › eclipse hss tool broken in 2
  • #323281
    lug lord
      @luglord
      Just ground myself a really nice facing tool for plastic very sharp etc and when i took it out of my tool post it was broken in 2
      what would cause this is the tool post uneven am i tightning the screws too much
      or is it just a very old hss tool piece probably older than me maybe been dropped on the floor
      any ideas thanks
      #8925
      lug lord
        @luglord
        #323293
        David Standing 1
          @davidstanding1
          What sort of tool post is it?
          Was there swarf under one end of the tool?
          A photograph would help.
          Edited By David Standing 1 on 24/10/2017 17:37:54
          #323300
          not done it yet
            @notdoneityet
            The position at which it fractured should give you some indication of the likely cause.
            If not a straightness of holder problem, it could be caused by tightening down beyond any packing pieces.
            While the tightening screws do not need to be extreeemly tight, over-tightening should more likely damage the screws/threads of the holder.
            #323305
            Mick B1
              @mickb1
              I've done that to a 1/4" square bit when I tightened all 3 toolpost screws down onto it, but had forgotten that the packing only extended under the front 2. Didn't know I'd done it till I took the tool out.
              #323315
              lug lord
                @luglord
                Its a 4 tool post myford super 7 i think it might have been swarf under the tool maybe as i broke 2 tools one after another
                #323316
                David Standing 1
                  @davidstanding1
                  Always brush your tool holder out before putting a tool in!
                  But you know that now………blush
                  #323318
                  David Standing 1
                    @davidstanding1
                    By the way, with my reply to your RDG thread, it isn't 'pick on lug lord' day, honest blush
                    #323325
                      Posted by lug lord on 24/10/2017 16:16:26:
                      any ideas thanks
                      Are you sure the metal is HSS? I wonder if you have tool-steel – it's more brittle.
                      Mike Poole
                        @mikepoole82104
                        I was taught to put a piece of packing between the screws and the tool bit to minimise any tendency to a point contact.
                        #323329
                        lug lord
                          @luglord
                          Posted by SillyOldDuffer on 24/10/2017 18:49:08:
                          any ideas thanks
                          not sure there very old tools for sure came in an old wooden cigar box ian
                          #323385
                          Hopper
                            @hopper
                            Posted by Mike Poole on 24/10/2017 19:00:08:
                            Now there's a good tip. I learn something new on this site every day.
                            #323421
                            lug lord
                              @luglord
                              Posted by Hopper on 25/10/2017 05:52:32:
                              Cheers for advice in future I will use a thick shim on the top to stop the point of the screws on the tools and make sure no swarf on my tool post thanks ian
                              #323498
                                Posted by lug lord on 25/10/2017 10:13:33:
                                … and make sure no swarf on my tool post thanks ian
                                Not just on the tool-post. Swarf goes everywhere it's not wanted. D*** stuff is a pain in the rear-end, sometimes literally!
                                Well worth keeping chucks and leadscrews etc clean with a toothbrush. In theory I wipe off bearing surfaces like tapers and chuck backs every time I change tool. (In practice I often forget but that's a different problem.) Quite small bits of swarf in the wrong place can throw accuracy off as well as cause damage.
