The ML7 is fitted with plain bearings, which have advantages and disadvantages. They're cheap and easy to make, and they were a good way keeping vibration low compared with the inferior ball-bearings of the day, which tended to brinell due to the difficulty of making perfect spheres and rollers. The brinell problem was cracked during the 1930's but didn't become generally available due to trade secrets and patents until after WW2. The main disadvantages of plain bearings are all related to lubrication difficulties. When the bearing is stopped, there's metal to metal contact, which causes severe wear and high start friction until the oil pressure builds up enough for the bearing to float in it. It's essential to have enough oil in the system for the bearing to float, otherwise a bearing that should last 40 years has to be replaced prematurely.
How quickly wear kills a bearing depends on the load, speed, and number of stop-starts. It's not a fast process, making it easy for owners to assume their oil regime is OK, when it's not. Wear caused by previous neglect and/or hard work is probably the cause of high oil-consumption : the gap is big enough to leak when the lathe is stopped and a lot of oil is needed to pressurise the bearing when turning.
The most important goal is to ensure there's enough oil in the system. Any oil is better than nothing, but the manufacturers recommendation is best. The viscosity matters most – too thin will flow rapidly through the system and make it hard to reach operating pressure; too thick means not enough oil will be available to reach operating pressure. The feed system matters:
- Large plain bearings are pressure fed oil from a pump
- Small bearings can be drip fed, or filtered through a felt pad, or syphoned in.
For cheapness, Myford used a simple drip system – not scientifically accurate, but completely adequate provided the owner remembers to turn the tap on and off between sessions, and puts a reasonable type of oil in.
I don't see any point in using EP90 on a Myford. It's an 'Extreme Pressure' oil, formulated to survive the hot mincing action of a gear-box transmitting significant power. EP oil is modified and contains additives, one of which attacks Copper. Mustn't be used on Brass or Bronze. Not ideal for the slow, cool, plain bearing on a Myford lathe, and might be harmful in the long run.
Noel mentions SAE 10 which sounds right to me. And if the bearing is leaky due to wear, I think more oil is needed, not restricting the flow to save a few quid!
Owning an older lathe means it's going to need repairs; when a bearing is done for, don't fiddle with the oil, replace the bearing! I don't suppose Myford expected their lathes to still be in perfect running order 70 years after coming out of the factory.
Edited By SillyOldDuffer on 17/05/2022 11:14:49
