Eagle Surface grinder – who here uses one?
Home Forums Manual machine tools Eagle Surface grinder – who here uses one?
Viewing 11 posts - 26 through 36 (of 36 total)
  • #524010
    not done it yet
      @notdoneityet
      It will be interesting to compare your weights with my machine. Are you not going to weigh the base and column?
      I used my 250kg load cell suspended from a plate bolted in the roof.🙂
      https://www.model-engineer.co.uk/forums/postings.asp?th=169212
      Ian Skeldon 2
        @ianskeldon2
        Wow great job Pete.
        #524023
        James B
          @jamesb
          Hi Pete,
          Thanks for the info – so on yours, does the outer race rest against a collar pressed onto the bore of the housing, or does yours have a machined step to rest against? Please don't pull your machine apart on my account, but if you happen to have chance to get any photos around the wheel head it would be useful – thank you.
          Hi NDIY,
          I see what you mean about the outside pulley – that does look a good arrangement. Mine has the belt in between the bearings, similar to Pete's machine it would seem. The belt on mine measures approximately 90 inches long – which does seem a lot. Have you noticed any problems with belt flap? I'm thinking of putting two jockey wheels half way up the column to reduce this, maybe with a poly fee belt as Pete's – not sure if that would help or not.
          Hi Mark,
          Good luck with your machine. It's really good to find such a useful source of information – when I started mine a few years back I couldn't find much at all, and it has sat unfinished for a while. I will take a few pics tomorrow of mine – it has the knee assembled, and I have been working on the saddle today – maybe of some use to you.
          James
          #524025
          James B
            @jamesb
            Also Pete – meant to say, have read your thread on the mig welding forum start to finish, really impressive stuff.
            #524032
            MARK RIGG
              @markrigg57943
              Hello again . I`ve got a cheap battery operated 300 KG load cell I bought on E bay. Suspend this from my engine crane . I did weigh the base casting the other day but I`ve since lost the piece of paper I wrote the weight down !.
              The smaller parts I`ll use the bathroom scales ( when the `boss` is not not looking ! )
              MARK
              BRIDGNORTH
              #524110
              Pete Rimmer
                @peterimmer30576
                Posted by James Burden on 31/01/2021 20:08:04:
                Thanks you!
                Yes you're right my housing has a step to seat the outer races against at the back. The spindle also has a step for the inner races. The outer races are clamped by the nose piece at the front and the inner races by the wheel hub.
                #534132
                MARK RIGG
                  @markrigg57943
                  Hello all . At last I have made room in my workshop, got the base , column and knee assembly installed . The general condition is good and the slides are in nice condition except for a small area of galling which is no problem .
                  I am thinking that the means of lubricating the slides and screws is very minimal which is something I am going to correct and fit more oiling points and some internal pipework . What oil nipples there are, a grease gun has been used which is surely not the best lubricant. What does anyone think ? I`d be interested in any comments .
                  MARK
                  BRIDGNORTH
                  #549101
                  MARK RIGG
                    @markrigg57943
                    Hello fellow Eagle grinder folk .
                    I have just completed the reassembly of my Eagle surface grinder , and this included changing the motor to a I hp single phase unit .
                    I have weighed the individual ` lumps ` and the total weight of the complete machine with the mag. chuck fitted comes out at 330 Kilos . The base unit ( without the motor or mounting plate ) is the heaviest part at 127 kilos .
                    Whilst the machine has been in pieces I have made some additions to the lubrication of the slides . This has involved drilling additional oilways, machining new oil grooves in the removable gibs and fitting several oil nipples to feed the oil in . I would appear that the original manufacturers did bother to much about the lubrication !
                    Anyway , I have pumped in plenty of oil and all feels OK – just need a DOL starter to complete the electrics and I can see how the machine performs !
                    Then on to the next project – the reassembly of the Elliott 10 M Shaper – not a lot to do to this apart from mounting it on casters and fitting a VFD to the original motor And then there`s the CVA LATHE to sort .
                    Can`t buy anything else – got nowhere to put it in the workshop now !! Oh , just forgot about the nice Pollard pillar drill that needs a repaint , reassembly , a new spindle to up grade from 1 to 2 MT or possibly 3 MT , a larger 3 phase motor and a VFD to run it and lower the speed . Where will it go ?? It will up grade the Meddings and the I can sell it – problem solved !
                    #549124
                    not done it yet
                      @notdoneityet
                      Wow! That has surprised me. The base, weighing nearly 30kg more than mine, yet the total weight being 25kg less means there was a reduction of about 55kg (in the column and working parts) for that later machine.
                      The difference could partly be table travel and cross feed, I suppose. My model is 18” x 8”. What is yours?
                      11kg of that difference could also be accounted for if yours has a smaller magnetic chuck.
                      #549156
                      Pete Rimmer
                        @peterimmer30576
                        My travel and cross feed aren't nearly that much, about 14 and 6 inches or so.
                        #549182
                        not done it yet
                          @notdoneityet
                          Posted by Pete Rimmer on 10/06/2021 16:32:52:
                          Yep, long travel stops are 20” apart and bed is 8” wide. Needs about 53” of space for the full long travel operation.
                          Probably need a right narrow wheel to use all the bed width. The only wheel I have is 200mm diameter x 20mm wide and it easily cleared a Morris Minor block when I ground the deck. Have an A series cylinder head (or two) as the next job lined up for it. I initially thought I might need a smaller diameter wheel to do the block but it fitted on nicely.
