Drill Press upgrade
Drill Press upgrade
Home › Forums › Workshop Techniques › Drill Press upgrade
  • #52413
    Steve Wan
      @stevewan33894
      Hi guys
      Has anyone tried upgrading your basic drill press with a fine feed attachment?
      Any design ideas to share and is it important to house the worm and worm gear in an enclose casing?
      I figure out that the worm gear would be part of the hand feed handle.
      Thanks inadvance.
      Steve Wan
      #15473
      Steve Wan
        @stevewan33894
        Drill Press upgrade with fine feed gear?
        #52430
        Sub Mandrel
          @submandrel
          Hi Steve
          The fine feed attachments for  bench mills are so crude a good design to suit both small mills and drill presses would generate a deal of interest!
          Steve Garnett
            @stevegarnett62550
            I would have thought that as a basic design idea, you’d have an enclosed worm system as a replacement for the original quill feed handles, and move these out by the depth of your additional section with the worm drive, etc. and have a means of reattaching the originals. The only real snag with any design like this is that you have to have a means of detaching the worm drive so that the original handles can still be used. On our Warco Major mill/drill this is achieved by a friction lock that when loosened, releases the worm gear.
            The only other snag with the whole arrangement is that as Neil points out, bench drills are generally pretty crude in their quill arrangements anyway, and to make any serious use of an attachment like this (which I think is a good idea), you may well have to make arrangements to tighten up the workings of the whole quill to get all of the potential accuracy benefits.
            It’s of interest to me, because I have a Meddings Pacera to rebuild, and adding a fine feed is something I’ve contemplated.
            #52440
            modeng2000
              @modeng2000
              A fine down feed for a mill has been discussed in this thread ‘Hobbymat MD65 needs assistance to start’
              Posted by Jim Whetren on 31/05/2010
              11:46:57
              Hello Joe,
              Thank you for your kind
              comments.
              As it
              happens, I did write an article on this mod at the end of March 2008. I
              presume it is as they say, in ‘The Pipeline’.
              Watch this space?
              Jim
            Home › Forums › Workshop Techniques › Topics
