Drill ginding jig Picador design
Home › Forums › Help and Assistance! (Offered or Wanted) › Drill ginding jig Picador design
  • #366895
    BOB BLACKSHAW 1
      @bobblackshaw1
      I've picked up a manual drill grinding jig, the Picador design.
      I am at the moment what is the best side of the wheel to fit it, Picador on the instructions have the drill on the side, other designs on the front.
      They may be no good but they have been going for years so worth a try
      Bob.
      #33247
      BOB BLACKSHAW 1
        @bobblackshaw1
        #366896
        Russell Eberhardt
          @russelleberhardt48058
          It does need to go on the side. Not considered to be good practice but for the small amount of metal removal for sharpening drills it's fine.
          It's worth having a look at Harold Hall's website for how to use it, http://homews.co.uk/page354.html
          Russell
          Edited By Russell Eberhardt on 12/08/2018 10:00:33
          #366903
          Ian S C
            @iansc
            If you need to grind a larger amount of the drill, do that freehand on the front of the wheel, then to finish sharpening put it in the sharpener, that will also show you how near you freehand grinding is.
            Ian S C
