Drill bits
Drill bits
Home › Forums › General Questions › Drill bits
  • #25470
    Vic
      @vic
      #314891
      Vic
        @vic
        How do they make them? I know the shank is soft so is it a different type of steel or is it just HSS that's left soft somehow. If anyone has a link to a "how's it made" video that would be great.
        #314897
        Ian S C
          @iansc
          From what I know the flutes are ground, they are made of one piece of steel, the flute area is hardened, whike the shank is left unhardened.
          Ian S C
          #314898
          Nick Hughes
            @nickhughes97026
            Hi Vic,
            the smaller sizes have the HSS Flash Butt Welded to the softer shank and the larger (usually morse tapere shank) are Friction Welded.
            It's also possible that some manufacturers may have Induction Hardened part of the HSS blank, to achieve the same result.
            Searching for Flash Butt Welding, Butt Flash Welding, Friction Welding and Induction Hardening will bring up plenty of information on the processes for you.
            Nick.
            Edited By Nick Hughes on 02/09/2017 11:24:19
            #314902
            Gordon Tarling
              @gordontarling37126
              Plenty of videos here!
              #314907
              Vic
                @vic
                I asked partly because I recently bought some new ground HSS drill bits which are self colour and you can't see any difference in colour along the length of the bit.
                #314910
                Vic
                  @vic
                  Posted by Gordon Tarling on 02/09/2017 11:43:11:
                  Thanks for that Gordon!
                  #314929
                  Vic
                    @vic
                    This is another one for anyone interested.
                    Speedy Builder5
                      @speedybuilder5
                      Friction butt welding – now there's a thought ! Avoided by using silicone polish on the seat I suppose. I believe new ends can be welded this way onto Austin 7 Half Shafts.
                      BobH
