Drill bit types
Drill bit types
Home Forums Beginners questions Drill bit types
  • #5314
    Goran Hosinsky
      @goranhosinsky61367
      #59946
      Goran Hosinsky
        @goranhosinsky61367
        There seems to be two basic HSS drill bit types, the rolled one and the ground one, the second being somewhat more expensive. What is the difference in use?
        Goran
        Canary Islands
        #59947
        Speedy Builder5
          @speedybuilder5
          Never come accross a rolled drill bit, just plain machined, and machined with clearance lands right the way up the drill on the edges of the spiral.
          #59949
          Goran Hosinsky
            @goranhosinsky61367
            Perhaps I am using the wrong terms but what I seen in the catalogues are
            Rolled high speed, straight shank HSS drill bit
             respective
            HSS fully ground drill bits,
            Goran
            #59960
              The rolled ones are a cheap basic form of manufacture, OK for a bit of DIY around the house but they are not as good as fully ground bits being more likely to wander, fracture of cut over/under size.
              The main flute pattern is rolled and then the edges ground whereas a fully ground bit has the flutes and edges ground
              Jason
              #313921
              larry Phelan
                @larryphelan54019
                I have some rolled drill bits and never have any problem with them.
                #313952
                Clive Hartland
                  @clivehartland94829
                  There was a programme on Discovery about drills being manufactured and they showed the flutes being milled both at the same time. The profiles of the flutes ground into the special cutters.
