Dremel 3400 – what threads on tool ends?
Home › Forums › Manual machine tools › Dremel 3400 – what threads on tool ends?
  • #614130
    lawrence karthauser
      @lawrencekarthauser63108
      What is the thread on the end of the dremel 3400 flexible extenson>? Wan to mount it in sainsmart 3016 CNC machine
      Bosch cannot help me
      Thanks
      Lawrence
      #14662
      lawrence karthauser
        #614154
          dont know
          Sounds more like will not than cannot
          Sorry … my Dremel is pre-Bosch, so I cannot help you.
          I’m sure someone will be along soon …
          Edit: __ it might be worth asking Eternal Tools nicely:
          https://www.eternaltools.com/blog/complete-guide-to-your-dremel-rotary-tool
          Edited By Michael Gilligan on 19/09/2022 17:00:01
          #614167
          Anonymous
            I've got a Bosch Dremel 3000 is it the collet thread on flex extension, or the flex to tool body collar thread.?
            Collet thread -. I expected a metric thread but it's a weird one, major diameter is 7.05mm, too much to be an M7, and pitch was somewhere between 0.6 and 0.7 thread gauges. Tried a UNF gauge and 40tpi gave a good fit which is 0.635 bearing out the 0.6-0.7 I thought it was.So I haven't got a clue what the actual thread is, anyone else have a clue?…..or is it a Dremel/Bosch special to stop you using other make accessories ?
            Extension to tool body – is probably M19 (major measured at 18.65mm) x 2 (spot on gauge).
            #614175
            Another JohnS
              @anotherjohns
              From my notes,
              Body end thread – 3/4×12 TPI, or 19mmx2mm pitch
              Spindle 9/32 x 40 TPI
              but check it! My notes may be wrong, or for a different Dremel than you have.
              #614222
              lawrence karthauser
                I found an adaptor for the main tool itself, "Adapter Ø 43 mm 3/4" x 12 pitch (Dremel)"
                but I am looking for the outside thread on the far end of the flexible extension.
                Thanks
                Lawrence
                #614229
                Andrew Entwistle
                  @andrewentwistle
                  Hi Lawrence,
                  I have measured it as 12.5 / 11.1 mm 20 TPI and 60 degree angle, so 1/2" UNF
                  Andrew.
