Dovetail Cutters
Dovetail Cutters
Home › Forums › Beginners questions › Dovetail Cutters
  • #102238
    Trevorh
      @trevorh
      I am just starting the HH Grinding rest and have what may seem to be a simple question, the dovetail cutter, when we say 30 degree or 60 degree from what plane is the angle talking about?
      What I mean to say is – is it 30 degree from the horizontal or the vertical plane?
      Hope I have explained myself
      thanks
      #6412
      Trevorh
        @trevorh
        #102244
        KWIL
          @kwil
          Measured up from the horizontal plane. Think about it, if the other way around, the resulting sliding assembly would be very shallow.
          #102246
          Trevorh
            @trevorh
            To be honest thats what prompted the question when I was looking at it – it just looked wrong so I then started to think which way was the dovetail measured
            thanks
            #102248
            KWIL
              @kwil
              Beware, not all "60 degree" dovetail slides are in fact 60, some are 55!
              #102250
              Trevorh
                @trevorh
                In this particular case would that really be an issue as the same cutter would be used to create the 2 mating parts, I understand the argument for getting what you ask for ie 60 degree should be 60 degree but as long as I use the same cutter it shouldn't really make a difference – or would it?
                #102253
                KWIL
                  @kwil
                  No, get a 60. What I was pointing out that some machines that look like they have 60 degree dovetails in fact have 55, don't ask! Sussex tools a good source.
                  #102256
                  Trevorh
                    @trevorh
                    Thanks for the tip Kwil I will give them a ring
                    thanks for the advice
                    #102265
                    Anonymous
                      Posted by KWIL on 30/10/2012 10:42:54:
                      I won't ask, I'll just say Bridgeport.
                      #102268
                      KWIL
                        @kwil
                        And M300
