Dore Westbury Mill
Dore Westbury Mill
Home Forums General Questions Dore Westbury Mill
Viewing 26 post (of 26 total)
  • #401043
    Brian Wood
      @brianwood45127
      Maurice,
      Try using a laser board pointer mounted off the machine and aimed at some distant point in your workshop, that will get you back on datum; they are now cheap enough to be useful for that kind of duty.
      The swing on the column can be useful if you have a long job on the table, rather on the lines of a radial arm drill to reach the distant parts; something you will not be able to do using a rigid column machine. For 'normal' work I do agree it is a nuisance
      Edited By Brian Wood on 18/03/2019 16:42:46
